April 9, 2011, 14:27 |
SIGFPE in reactingFoam(LES)
Luigi
Rep Power: 15 |
I obtain a floating point exception when I run reactingFoam using a LesModel. From gdb: if (turbulentReaction) (gdb) 14 Cmix*sqrt(turbulence->muEff()/rho/turbulence->epsilon()); (gdb) n Program received signal SIGFPE, Arithmetic exception. 0x01a9b232 in Foam::divide (res=..., f1=..., f2=...) at fields/Fields/scalarField/scalarField.C:95 95 BINARY_OPERATOR(scalar, scalar, scalar, /, divide) In 0 directory I don't assign a value for muEff, rho as well as for epsilon and I don't see the need to assign one in Les. |
June 6, 2011, 09:08 |
#2 | |
Martin
Rep Power: 17 |
in reactingfoam you use the partially stirred reactor, which needs some fields like k or epsilon. I'm new to Openfoam, but would like to use the PaSR for my case, also with LES turbulence model. My Question is: Is there anyone, who already used reactingfoam with LES. How did you calculate epsilon? Thanks for any answers. |
August 4, 2016, 05:16 |
#3 | |
sudhakar singh
Rep Power: 9 |
whick LES model you are using?? I am new to Openfoam. I am simulating a simple jet (CH4) and coflow (air) problem but when i am using RAS model, jet is spreading and mixing well but when i tried to use LES model, jet is not spreading. Jet is going straight. no mixing is taking place and it is not looking LES from any angle. what would be the problem? what changes should be done to implement LES model in reactingFoam?? Last edited by wyldckat; August 20, 2016 at 16:39. Reason: posted a few minutes apart |
Display Modes | |
Error Message sigFpe | AlpAc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2011 03:41 |
ICC compiler and sigFpe for sample utility | cfdmarkus | OpenFOAM Installation | 3 | June 25, 2010 14:31 |
chtMultiFoam sigFpe | HendrikR | OpenFOAM | 6 | April 2, 2010 10:40 |
dieselEngineFoam OpenFOAM-1.6 SigFPE error | arun | OpenFOAM Running, Solving & CFD | 0 | September 24, 2009 04:32 |
meshing error in Gambit: SIGFPE | Ralf Schmidt | FLUENT | 0 | November 2, 2005 15:28 |
