Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
floating point exception error for eigenvalue calculation in applications/test/tensor
Old   November 16, 2016, 10:11
Default floating point exception error for eigenvalue calculation in applications/test/tensor
SSSSS
doctorWho is on a distinguished road
I am using OpenFOAM 4.x and found that applications/test/tensor make a floating point exception error.
in the below code, vector e = eigenValues(t6) makes the error
    tensor t6(1,0,-4,0,5,4,-4,4,3);
    //tensor t6(1,2,0,2,5,0,0,0,0);
    Info<< "tensor " << t6 << endl;
    vector e = eigenValues(t6);
    Info<< "eigenvalues " << e << endl;
problematic part is in the member function eigenValues(const tensor& t) of src/OpenFOAM/primitives/Tensor/tensor/tensor.C
in the code below, Q makes zero for the test matrix (1 0 -4 0 5 4 -4 4 3) which has eigen values (-3, 3, 9). So when checking mag(PPP/QQ -1), it leads to floating point exception error before going to the third conditional PPP > QQ.
The same test code works for OpenFOAM 2.3.0 but not work for OpenFOAM 4.x (also 3.0.x). I don't know much about the OpenFOAM code but it looks like a bug after version 3.0.x. Maybe Henry Weller can fix this behavior.
    // non-diagonal matrix
    else
        // Coefficients of the characteristic polynmial
        // x^3 + a*x^2 + b*x + c = 0
        scalar a =
           - t.xx() - t.yy() - t.zz();
        scalar b =
            t.xx()*t.yy() + t.xx()*t.zz() + t.yy()*t.zz()
          - t.xy()*t.yx() - t.yz()*t.zy() - t.zx()*t.xz();
        scalar c =
          - t.xx()*t.yy()*t.zz()
          - t.xy()*t.yz()*t.zx() - t.xz()*t.zy()*t.yx()
          + t.xx()*t.yz()*t.zy() + t.yy()*t.zx()*t.xz() + t.zz()*t.xy()*t.yx();
        // Auxillary variables
        scalar aBy3 = a/3;
        scalar P = (a*a - 3*b)/9; // == -p_wikipedia/3
        scalar PPP = P*P*P;
        scalar Q = (2*a*a*a - 9*a*b + 27*c)/54; // == q_wikipedia/2
        scalar QQ = Q*Q;
        // Three identical roots
        if (mag(P) < SMALL && mag(Q) < SMALL)
            return vector(- aBy3, - aBy3, - aBy3);
        // Two identical roots and one distinct root
        else if (mag(PPP/QQ - 1) < SMALL)
            scalar sqrtP = sqrt(P);
            scalar signQ = sign(Q);
            i = ii = signQ*sqrtP - aBy3;
            iii = - 2*signQ*sqrtP - aBy3;
doctorWho is offline   Reply With Quote
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 11:43
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 04:57
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 13:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 19:28
