foamExec does not find applications
Good evening,
I have installed OpenFOAM 2.3.1 on Ubuntu 18.04 and need to use foamExec for some scripts. foamExec however does not find any applications, which are otherwise run just fine when I source the bash-file of OpenFOAM. This is what I get: $HOME/OpenFOAM/OpenFOAM-2.3.1/bin/foamExec simpleFoam /home/tobias/OpenFOAM/OpenFOAM-2.3.1/bin/foamExec: 145: exec: simpleFoam: not found Does anyone have an idea where I could start looking why it doesn't work? Best regards and thanks in advance |
Quick question: Why are you already trying to use Ubuntu 18.04, when it's still in beta? Because it is somewhat possible that this is a bug in Ubuntu 18.04...
I could not get older versions of Ubuntu to work on my laptop.
But I found the issue in the meantime: export WM_COMPILER was not set correctly in OpenFOAMs bashrc. Once I set it to the Compiler I used, foamExec found all the applications. |
