Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
environment variable MPI_BUFFER_SIZE not defined when running a parallel case
Old   January 18, 2021, 06:41
Default environment variable MPI_BUFFER_SIZE not defined when running a parallel case
Rokas Bytautas
rokasbytautas is on a distinguished road
I'm quite new to OpenFoam and I'm trying to learn how to simulate rotating movement. I'm getting the following error when trying to run a parallel case for rotating fan in room tutorial:
--> FOAM FATAL ERROR:
[1] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[1]
[1] From function static bool Foam::UPstream::init(int&, char**&)
Hope somebody is able to help as I've looked for answers online but now I'm quite stuck.
Full script after running mpirun command:
rbytautas@Tomas-PC:~/OpenFOAM/OpenFOAM-v2006/tutorials/incompressible/pimpleFoam/RAS/rotatingFanInRoom1/case$ mpirun -np 4 pimpleFoam -parallel > log.pimpleFoam &
[1] 40
rbytautas@Tomas-PC:~/OpenFOAM/OpenFOAM-v2006/tutorials/incompressible/pimpleFoam/RAS/rotatingFanInRoom1/case$ [1]
[1]
[1] --> FOAM FATAL ERROR:
[1]
[1] [2]
[2]
[2] --> FOAM FATAL ERROR:
[2] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[2]
[2] From function static bool Foam::UPstream::init(int&, char**&)
[2] [0]
[0]
[0] --> FOAM FATAL ERROR:
[0] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[0]
[0] From function static bool Foam::UPstream::init(int&, char**&)
[0] in file UPstream.C at line 103.
[0]
FOAM parallel run aborting
[0]
[1]
[1]
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] UPstream::init(int& argc, char**& argv) : environment variable MPI_BUFFER_SIZE not defined
[3]
[3] From function static bool Foam::UPstream::init(int&, char**&)
[3] in file UPstream.C at line 103.
[3]
[3]
[2]
[2]
[2] #0 Foam::error:rintStack(Foam::Ostream&)[3] #0 Foam::error:rintStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&)[1] #0 Foam::error:rintStack(Foam::Ostream&)sh: 1: addr2line: not found
addr2line failed
[0] #1 Foam::error::abort() addr2line failed
[2] #1 Foam::error::abort()sh: 1: addr2line: not found
addr2line failed
[3] #1 Foam::error::abort()sh: 1: addr2line: not found
addr2line failed
[1] #1 Foam::error::abort()sh: 1: addr2line: not found
addr2line failed
[3] #2 Foam::UPstream::init(int&, char**&) addr2line failed
[0] #2 Foam::UPstream::init(int&, char**&)sh: 1: addr2line: not found
addr2line failed
[2] #2 Foam::UPstream::init(int&, char**&)sh: 1: addr2line: not found
addr2line failed
[1] #2 Foam::UPstream::init(int&, char**&)sh: 1: addr2line: not found
addr2line failed
[0] #3 Foam::argList::argList(int&, char**&, bool, bool, bool)sh: 1: addr2line: not found
addr2line failed
[3] #3 Foam::argList::argList(int&, char**&, bool, bool, bool)sh: 1: addr2line: not found
addr2line failed
[2] #3 Foam::argList::argList(int&, char**&, bool, bool, bool)sh: 1: addr2line: not found
addr2line failed
[1] #3 Foam::argList::argList(int&, char**&, bool, bool, bool)sh: 1: addr2line: not found
addr2line failed
[0] #4 sh: 1: addr2line: not found
addr2line failed
[3] #4 sh: 1: addr2line: not found
addr2line failed
[1] #4 sh: 1: addr2line: not found
addr2line failed
[2] #4 ????sh: 1: addr2line: not found
addr2line failed
[0] #5 __libc_start_mainsh: 1: addr2line: not found
addr2line failed
[3] #5 __libc_start_mainsh: 1: addr2line: not found
addr2line failed
[1] #5 __libc_start_mainsh: 1: addr2line: not found
addr2line failed
[2] #5 __libc_start_mainsh: 1: addr2line: not found
addr2line failed
[0] #6 sh: 1: addr2line: not found
addr2line failed
[3] #6 sh: 1: addr2line: not found
addr2line failed
[1] #6 ?sh: 1: addr2line: not found
addr2line failed
[2] #6 ??sh: 1: addr2line: not found
addr2line failed
[Tomas-PC:00040] 3 more processes have sent help message help-btl-vader.txt / cma-permission-denied
[Tomas-PC:00040] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
rokasbytautas is offline   Reply With Quote
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 10:25
Running parallel case after parallel meshing with snappyHexMesh? Adam Persson OpenFOAM Running, Solving & CFD 0 August 31, 2015 22:04
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 04:59
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
