steadyUniversalMRFFoam Tutorial fails in MixingPlane |
February 14, 2019, 04:48 |
Henrik Johansson
Rep Power: 8 |
I have ran into a problem regarding the mixingPlane function in foam-extend. When running the steadyUniversalMRFFoam tutorial in parallel with ten times larger mesh in all axises it fails. Works fine in serial thus I think the fault lie within the decomposition method used. It fails when running the Initalization of the mixing plane or GGI. I seem to get the error when I increase the radial element count above 80. In this case I tried with 100 elements. I have tried foam-extend 4.1 aswell as 4.0 and booth gives the same error. I have attached the tutorial that gives me the error. The error I get: Code:
Create time Create mesh for time = 0 mixingPlane patch Master: GVOUTLET Slave: RUINLET is local parallel mixingPlane patch Master: RUINLET Slave: GVOUTLET is local parallel mixingPlane patch Master: RUOUTLET Slave: DTINLET is local parallel Initializing the GGI interpolator between master/shadow patches: RUCYCLIC1/RUCYCLIC2 mixingPlane patch Master: DTINLET Slave: RUOUTLET is local parallel Initializing the GGI interpolator between master/shadow patches: DTCYCLIC1/DTCYCLIC2 [2] [2] [2] --> FOAM FATAL IO ERROR: [2] Expected a '(' or a '{' while reading List, found on line 0 an error [2] [2] file: IOstream at line 0. [2] [2] From function Istream::readBeginList(const char*) [2] in file db/IOstreams/IOstreams/Istream.C at line 130. [2] FOAM parallel run exiting [2] Code:
From function MixingPlaneInterpolation<MasterPatch, SlavePatch>::calcMixingPlanePatch() const in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/MixingPlaneInterpolationPatches.C at line 333 minSpan from patch BB : -5.07657818944 maxSpan from patch BB : 9.27844514192 From function MixingPlaneInterpolation<MasterPatch, SlavePatch>::calcMixingPlanePatch() const in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/MixingPlaneInterpolationPatches.C at line 354 minSpan after checking spanLimited: -180 maxSpan after checking spanLimited: 180 From function MixingPlaneInterpolation<MasterPatch, SlavePatch>::calcMixingPlanePatch() const in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/MixingPlaneInterpolationPatches.C at line 412 mixingPatch: Code:
From function MixingPlaneInterpolation<SlavePatch, SlavePatch>::calcTransforms() const in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/MixingPlaneInterpolationAddressing.C at line 361 slave face centre transformation check: (should be zero!) mag = But the solver crashed since the mixingPlane faces were not constrained to one patch as the need to. Guess it could be something within patchConstrained method. I can also see now that the error is not only due to the mixing plane. It also occurs from initializing the GGI interpolator. So the fault may lie in the GGI code. Appyling debug switches to the GGI I get the following: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 mixingPlane patch Master: GVOUTLET Slave: RUINLET is local parallel mixingPlane patch Master: RUINLET Slave: GVOUTLET is local parallel mixingPlane patch Master: RUOUTLET Slave: DTINLET is local parallel [0] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 Initializing the GGI interpolator between master/shadow patches: RUCYCLIC1/RUCYCLIC2 From function void ggiPolyPatch::calcPatchToPatch() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 211 Calculating patch to patch interpolation for patchRUCYCLIC1 [2] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 [3] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 [4] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 [7] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 [1] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 [5] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 [6] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC1 From function void GGIInterpolation<MasterPatch, SlavePatch>::calcAddressing() const in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 114 Evaluation of GGI weighting factors: From function GGIInterpolation::findNonOverlappingFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 829 : Found 0 non-overlapping faces for this GGI patch From function GGIInterpolation::findNonOverlappingFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 829 : Found 0 non-overlapping faces for this GGI patch From function GGIInterpolation::calcPartiallyCoveredFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 909 : Found 0 partially overlapping faces for master GGI patch From function GGIInterpolation::calcPartiallyCoveredFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 933 : Found 0 partially overlapping faces for slave GGI patch Largest slave weighting factor correction : 2.22044604925e-16 average: 5.41788836017e-17 Largest master weighting factor correction: 5.21764348393e-08 average: 1.3359972925e-08 [3] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 [1] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 [5] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 [4] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 Allocating communicator for GGI patch RUCYCLIC1 with 3(1 5 6): 1 GGI patch Master: RUCYCLIC1 Slave: RUCYCLIC2 is split between multiple processors [0] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 [7] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 [6] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 [2] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC1 [5] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [2] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [0] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [7] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [6] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [4] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [3] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [1] ggiPolyPatch::calcRemoteZoneAddressing() const for patch RUCYCLIC2 [1] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 [2] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 GGI patch Master: RUCYCLIC2 Slave: RUCYCLIC1 is split between multiple processors [0] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 [7] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 [6] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 [4] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 [3] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 [5] ggiPolyPatch::calcSendReceive() const for patch RUCYCLIC2 [2] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 mixingPlane patch Master: DTINLET Slave: RUOUTLET is local parallel [0] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 Initializing the GGI interpolator between master/shadow patches: DTCYCLIC1/DTCYCLIC2 From function void ggiPolyPatch::calcPatchToPatch() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 211 Calculating patch to patch interpolation for patchDTCYCLIC1 [7] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 [6] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 [3] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 [5] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 [4] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 [1] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC1 From function void GGIInterpolation<MasterPatch, SlavePatch>::calcAddressing() const in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 114 Evaluation of GGI weighting factors: From function GGIInterpolation::findNonOverlappingFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 829 : Found 0 non-overlapping faces for this GGI patch From function GGIInterpolation::findNonOverlappingFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 829 : Found 0 non-overlapping faces for this GGI patch From function GGIInterpolation::calcPartiallyCoveredFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 909 : Found 0 partially overlapping faces for master GGI patch From function GGIInterpolation::calcPartiallyCoveredFaces in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 933 : Found 0 partially overlapping faces for slave GGI patch Largest slave weighting factor correction : 2.22044604925e-16 average: 6.5883806347e-17 Largest master weighting factor correction: 2.62809629614e-08 average: 9.7988954088e-09 [2] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 [1] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 [7] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 [5] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 [6] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 Allocating communicator for GGI patch DTCYCLIC1 with 3(1 4 5): 2 GGI patch Master: DTCYCLIC1 Slave: DTCYCLIC2 is split between multiple processors [0] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 [4] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 [3] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC1 [3] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [0] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [4] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [2] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [1] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [5] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [7] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [6] ggiPolyPatch::calcRemoteZoneAddressing() const for patch DTCYCLIC2 [1] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 [6] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 [3] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 GGI patch Master: DTCYCLIC2 Slave: DTCYCLIC1 is split between multiple processors [0] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 [7] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 [4] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 [2] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 [5] ggiPolyPatch::calcSendReceive() const for patch DTCYCLIC2 From function void ggiPolyPatch::calcReconFaceCellCentres() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 279 Calculating recon centres for patch RUCYCLIC1 From function void ggiPolyPatch::calcReconFaceCellCentres() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 279 Calculating recon centres for patch DTCYCLIC1 [0] [0] [0] --> FOAM FATAL IO ERROR: [0] incorrect first token, expected <int> or '(', found on line 0 the word 'J' [0] [0] file: IOstream at line 0. [0] [0] From function operator>>(Istream&, List<T>&) [0] in file /home/henrik/foam/foam-extend-4.0/src/foam/lnInclude/ListIO.C at line 149. [0] FOAM parallel run exiting It was not... But it seems like the error occures in the ggiPolyPatch.C.
/ Henrik Johansson Last edited by HenrikJohansson; February 14, 2019 at 10:15. |
tutorial files | KITetima | FLUENT | 8 | November 23, 2019 16:05 |
AMI - Propeller Tutorial diverging | kingmaker | OpenFOAM Running, Solving & CFD | 2 | November 4, 2016 02:57 |
Foam-3.0-ext + MixingPlane Problems | lentschi | OpenFOAM Running, Solving & CFD | 3 | March 31, 2014 08:40 |
Fluent Tutorial Guide Ch. 17: Non-Premixed Combust, THTR | MAE7509 | FLUENT | 0 | January 22, 2014 20:59 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
