Wrong statement in OpenFOAM documentation
In the following page: https://cfd.direct/openfoam/user-gui...rocessing-cli/ Under the section 6.2 Post-processing command line interface (CLI) we can find the following sentence: Every solver can be run with the -postProcess option, which only executes post-processing, but with additional access to data available on the database for the particular solver. But when I try with the icoFoam solver: Code:
icoFoam -help Code:
postProcess I tried to report it but Henry keeps closing the bug report without any explanation!! What's wrong? |
The source code of e. g. simpleFoam includes the following file:
#include "postProcess.H" icoFoam does not. So it probably does not support post processing from within the solver. You could still use the postProcess tool. |
What is your conclusion??? It is very obvious that the sentence Every solver can be run with the -postProcess option is wrong because not all solvers have postProcess option (remember: postProcess when called alone is not an option) |
Have you tried to add the line to the solver source code and recompile it?
Quick answer @CFD_10: https://bugs.openfoam.org/view.php?id=2419 - read the first comment, which has the official answer, at least from the OpenFOAM Foundation.
But yes, Joachim is right, namely that you are free to create a modified version of icoFoam and add whichever features you want it to have... That said, you can also try using pisoFoam to at least assist in post-processing... although you might need to add one or two more files with the associated configuration that this solver needs... although you may want to use pisoFoam instead of icoFoam, which is a lot more feature-complete... |
