Is this a bug in wmake?
If I compile the wmake application below, I get the warning/error:
could not open file other.C for source file wtest.C due to No such file or directory Another problem is that if I change other.C and run wmake again, it does not get recompiled unless I run wclean. File structure: ├── other.C ├── outer.C └── wtest ├── Make │ ├── files │ └── options └── wtest.C File contents other.C: empty file outer.C: #include "other.C" wtest.C: #include "../outer.C" int main(){} options: empty file files: wtest.C EXE = wtest |
those are not bugs.
both of the 'bugs' could be changed by modify 'Make/files' and 'Make/options' 'wmake' is a script to call 'make'. You could find the way by figure out how 'makefile' works. |
Not a bug. Do
#include “outer.C” |
