Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
[Swak4Foam] can not get Swak4Foam to compile correctly for FoamExtend-0.4.0
Old   March 29, 2021, 12:02
Default [Swak4Foam] can not get Swak4Foam to compile correctly for FoamExtend-0.4.0
Christopher Roper
cmroper is on a distinguished road
I am trying to get Swak4Foam working on FoamExtend-0.4.0. funkySetFields does not work. I have attached part of the results of running ./Allwmake
Current OpenFOAM version is 4.0.
Previously compiled for OpenFOAM (4.0)
/home/ofpc/foam/ofpc-4.0/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
Looking for Python 2
Found Python 2.7
Configuring Python 2.7
Using python2.7 at /usr/bin/python2.7-config for python2
Looking for Python 3
Using our own Lua at /home/ofpc/foam/ofpc-4.0/swak4Foam/privateRequirements
Checking swak4Foam-version and generating file
Swak version is 20xx.yy.0
hg info: b8e73355892c (develop) tip
No 'bear' installed
Bison: /home/ofpc/foam/ofpc-4.0/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison at /home/ofpc/foam/ofpc-4.0/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4)
Flex is version 2.6.4 (Minor version: 4)
OpenFOAM-version: Major 4 Minor 0 Patch 0 (-1 == x / 0) Fork: extend
No change to swak4FoamParsers/foamVersion4swak.H
Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem
'/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libswak4FoamParsers.so' is up to date.
/usr/bin/ld: cannot find -lradiation
collect2: error: ld returned 1 exit status
/home/ofpc/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libswakLagrangianParser.so' failed
make: *** [/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libswakLagrangianParser.so] Error 1
'/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libgroovyBC.so' is up to date.
'/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libswakFunctionObjects.so' is up to date.
/usr/bin/ld: cannot find -lincompressibleTurbulenceModel
/usr/bin/ld: cannot find -lcompressibleTurbulenceModel
/home/ofpc/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libsimpleFunctionObjects.so' failed
make: *** [/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libsimpleFunctionObjects.so] Error 1
/home/ofpc/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libsimpleLagrangianFunctionObjects.so' failed
make: *** [/home/ofpc/foam/ofpc-4.0/lib/linux64GccDPOpt/libsimpleLagrangianFunctionObjects.so] Error 1
SOURCE=wrapperSearchableSurface.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DFOAM_DEV     -I../swak4FoamParsers/lnInclude     -I/home/ofpc/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/ofpc/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/ofpc/foam/foam-extend-4.0/src/triSurface/lnInclude -IlnInclude -I. -I/home/ofpc/foam/foam-extend-4.0/src/foam/lnInclude -I/home/ofpc/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/wrapperSearchableSurface.o
/usr/bin/ld: cannot find -lfoam
/home/ofpc/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/ofpc/foam/ofpc-4.0/applications/bin/linux64GccDPOpt/makeAxialMesh' failed
make: *** [/home/ofpc/foam/ofpc-4.0/applications/bin/linux64GccDPOpt/makeAxialMesh] Error 1
If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/ofpc/foam/ofpc-4.0/swak4Foam/Libraries (most people will be fine without setting that variable)
cmroper is offline   Reply With Quote
Cannot install swak4Foam correctly in cluster. Help! zxw OpenFOAM 0 September 15, 2018 10:37
[swak4Foam] Couldn't Compile swak4foam with OpenFOAM git p0kerus OpenFOAM Community Contributions 4 October 10, 2017 14:22
[swak4Foam] Error: Installing swak4Foam into OpenFOAM 2.3.0 on CentOS 7 mushtime OpenFOAM Community Contributions 9 July 23, 2017 15:27
[swak4Foam] something wrong when I compile swak4Foam whyingwang OpenFOAM Community Contributions 1 May 22, 2013 07:13
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
