Is there a bug in externalWallHeatFluxTemperature boundary condition ? |
September 19, 2021, 19:06 |
Rep Power: 7 |
Hi Everyone,
I am simulating evaporation/condensation using icoReactingMultiphaseInterFoam. I need to apply a uniform heat flux boundary condition over a wall. Hence, I chose to use externalWallHeatFluxTemperature boundary condition. But, my temperatures were very high and unphysical. Then, I plotted the wall heat flux and found that they are very high than the values I set. Is it a bug in externalWallHeatFluxTemperature boundary condition ? I am aware that I could use fixedGradient = heat flux/kappa. But, as I am working on a multiphase flow getting the right value of kappa is a bit complex. However, I am working on groovyBC to use a gradient Expression with the expression of kappa. But, still externalWallHeatFluxTemperature boundary condition would be a straight forward solution for me. Kindly please advice me on this. Thank You. With Thanks, Pavithra. |
January 12, 2022, 15:35 |
Julio Pieri
Rep Power: 8 |
I've been using this BC for long time without bug. However it is hard get proper variables, as you have many influencing parameters. I'd recommend going back to paper and pen and see if the heat balance of you walls make sense.
If you are using qr, then it's very important to use qrRelaxation |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Accessing multiple boundary patches from a custom boundary condition file | ripudaman | OpenFOAM Programming & Development | 0 | October 22, 2014 18:34 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
