SHOWING BUG - blockMesh
========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 11 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 11-d5b4d966c3c5 Exec : blockMesh Date : Sep 13 2023 Time : 18:16:32 Host : "DESKTOP-L1IMD32" PID : 5646 I/O : uncollated Case : /home/vishal/OpenFOAM/vishal-11/run/one/wavesimulation nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: problem while reading header for object controlDict file: /home/vishal/OpenFOAM/vishal-11/run/one/wavesimulation/system/controlDict at line 9. From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 560. FOAM exiting |
