January 24, 2009, 12:21 |
latest OF-1.5.x fixed the prob
Pei-Ying Hsieh
Rep Power: 18 |
latest OF-1.5.x fixed the problem when the domain rotating to 180 degree.
I just ran a case where the domain moves from 0 degree to 180 degree, then, rotates back from 180 to 0 degree. As time reached 0 degree, solver crashed. If I changed from 0 degree to 0.0001 degree, then, run continues without problem. Pei |
January 24, 2009, 13:25 |
Could you post the motion desc
Rep Power: 22 |
Could you post the motion description so we can reproduce the problem here?
Thanks H |
January 25, 2009, 15:32 |
Hi, Henry,
Below is the err
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Henry,
Below is the error message. I will see if I can post the motion profile. Pei --------------------- solidBodyMotionFunctions::SKA::transformation(): Time = 3.13106 transformation: ((0 0 0) (1 (0 0 9.15736e-06))) Execution time for mesh.update() = 0.07 s MULES: Solving for gamma Liquid phase volume fraction = 0.336652 Min(gamma) = 5.68349e-06 Max(gamma) = 0.998867 MULES: Solving for gamma Liquid phase volume fraction = 0.33665 Min(gamma) = 5.6871e-06 Max(gamma) = 0.998867 MULES: Solving for gamma Liquid phase volume fraction = 0.336648 Min(gamma) = 5.6871e-06 Max(gamma) = 0.998867 GAMG: Solving for pd, Initial residual = 0.0441962, Final residual = 0.000147613, No Iterations 2 time step continuity errors : sum local = 4.67942e-06, global = -5.79765e-17, cumulative = 5.09779e-16 GAMGPCG: Solving for pd, Initial residual = 0.00885975, Final residual = 4.89186e-10, No Iterations 6 time step continuity errors : sum local = 1.55695e-11, global = -5.80112e-17, cumulative = 4.51768e-16 ExecutionTime = 823.46 s ClockTime = 828 s Courant Number mean: 0.0425424 max: 0.446283 deltaT = 0.00378788 Time = 3.13485 solidBodyMotionFunctions::SKA::transformation(): Time = 3.13485 transformation: ((0 0 0) (1 (0 0 0))) Execution time for mesh.update() = 0.07 s #0 Foam::error::printStack(Foam:stream&) in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::surfaceInterpolation::makeWeights() const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::surfaceInterpolation::weights() const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::linear<double>::weights(Foam::GeometricField <double,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::surfaceInterpolationScheme<double>::interpol ate(Foam::GeometricField<doubl e,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libinterfaceProperties.s o" #7 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #8 Foam::tmp<foam::geometricfield<foam::outerproduct< foam::vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<double>(Foam::GeometricField<doubl e,> const&, Foam::word const&) in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libinterfaceProperties.s o" #9 Foam::tmp<foam::geometricfield<foam::outerproduct< foam::vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<double>(Foam::GeometricField<doubl e,> const&) in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libinterfaceProperties.s o" #10 Foam::LimitedScheme<double,>, Foam::limitFuncs::magSqr>::limiter(Foam::Geometric Field<double,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #11 Foam::limitedSurfaceInterpolationScheme<double>::w eights(Foam::GeometricField<do uble,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libinterfaceProperties.s o" #12 Foam::surfaceInterpolationScheme<double>::interpol ate(Foam::GeometricField<doubl e,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libinterfaceProperties.s o" #13 Foam::fv::gaussConvectionScheme<double>::interpola te(Foam::GeometricField<double ,> const&, Foam::GeometricField<double,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #14 Foam::fv::gaussConvectionScheme<double>::flux(Foam ::GeometricField<double,> const&, Foam::GeometricField<double,> const&) const in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #15 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::flux<double>(Foam::GeometricField<doubl e,> const&, Foam::GeometricField<double,> const&, Foam::word const&) in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interDyMFoa m" #16 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::flux<double>(Foam::tmp<foam::geometricf ield<double,> > const&, Foam::tmp<foam::geometricfield<double,> > const&, Foam::word const&) in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interDyMFoa m" #17 main in "/home/phsieh/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interDyMFoa m" #18 __libc_start_main in "/lib64/libc.so.6" #19 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception phsieh@huwei:~/OpenFOAM/phsieh-1.5/run/sloshingTank3D6DoF> --------------------- |
January 26, 2009, 07:17 |
Thanks for the bug report and
Rep Power: 22 |
Thanks for the bug report and the case setup. We have now fixed the problem and will push the fix to 1.5.x shortly.
H |
InterDyMFoam SDA SKA coefficients | markc | OpenFOAM Running, Solving & CFD | 14 | May 2, 2016 21:19 |
Restarting interDyMFoam | hsieh | OpenFOAM Bugs | 4 | January 25, 2009 15:19 |
Problems with interDyMFoam | qinnan | OpenFOAM Running, Solving & CFD | 0 | December 20, 2008 11:56 |
6DOF | Zolet | Siemens | 3 | November 18, 2008 21:36 |
6dof | Mike | FLUENT | 0 | May 15, 2008 08:17 |
