Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Rereading of ReactingParcels fails if one of the Phases has a fraction of 0
Old   January 7, 2009, 16:10
Default In ReactingParcelIO.C there is
Assistant Moderator
Bernhard Gschaider
In ReactingParcelIO.C there is an error that makes it fail if reading data from a previous run where some of the parcels have for instance a Y_liquid of 0 (division by zero). This patch fixes this:
ReactingParcelIO.patch
BTW: I haven't tested it, but it occurred to me during fixing this that if there was for instance a species H2O in the liquid and the solid phase of the parcel they both would get written to lagrangian/YH2O. I'd propose calling them YlH2O and YsH2O just to avoid such clashes (however unlikely they might be)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 8, 2009, 20:27
Default Bernhard, The reacting parc
Greg Collecutt
gcollecutt is on a distinguished road
Bernhard,
The reacting parcel class was originally written for modelling combustion of coal particles. The class was intended to allow the parcels to have a liquid component but the calcMassTransfer() routine is not yet able to support this - hence the class was never tested with liquid components.
Have you included some form evaporation/condensation in a mass transfer model?
Greg.
gcollecutt is offline   Reply With Quote
Old   January 12, 2009, 11:13
Default Hi Greg! Yes, I'm working o
Assistant Moderator
Bernhard Gschaider
Hi Greg!
Yes, I'm working on an evaporation model included. But the error also occurs for Y_gas and Y_solid equal to 0. I was only using Y_liquid as an example.
Bernhard
Old   January 12, 2009, 20:37
Default Bernhard, How have you stru
Greg Collecutt
Bernhard,
How have you structured the inclusion of the evaporation model? The massTransfer() routine was designed to call run time selectable devolatilisation models. I think it would be unwise to inlcude the liquid evaporation physics into the devolatilisation model - it should go in as its own model. In this case the parcelProperties dictionary should specify a both a devolatilisation model (or NoDevolatilisation) and an evaporation model (or NoEvaporisation). The reacting parcel template should likewise be modified to call these to models seperately and get rid of the generic call to massTransfer() which already is misleading since the surface reaction model also causes mass transfer.
Greg.
Old   January 13, 2009, 07:17
Default Hi Greg! You're right. I re
Assistant Moderator
Bernhard Gschaider
Hi Greg!
You're right. I rewrote massTransfer for my parcels and introduced a separate EvaporationModel-hierarchy.
Bernhard
Old   January 13, 2009, 14:29
Default Hi Berhhard, I have been wo
Greg Collecutt
Hi Berhhard,
I have been working with one of the guys at OpenCFD to develop the reacting parcel class. Is there a chance we could have a look at your code?
Greg.
Old   January 13, 2009, 16:34
Default Hi Greg! Got to check with
Assistant Moderator
Bernhard Gschaider
Hi Greg!
Got to check with our client whether it's OK if I removed the customer-specific stuff and gave it to you.
Bernhard
Volume fraction to mass fraction Torsaki CFX 10 March 10, 2018 03:41
equilibrium between phases chouki FLUENT 1 August 27, 2008 17:29
How set volume fraction and species mass fraction Reginaldo Cotto FLUENT 0 August 31, 2006 04:58
RunFoamX fails jvn OpenFOAM Installation 12 August 11, 2005 11:12
SOR Fails Near Walls Chih-Wei Chiu Main CFD Forum 0 May 9, 2002 01:05
