Jose Luis Santos
I am follo
Jose Luis Santos
I am following the method you posted regarding use of qt 4.4 (as in SUSE 11) for recompilation of paraView. You have a step in your procedure listed as: "Installed libqt4-devel package" Would you please indicate where to get that package and and how and where to install it. Thanks, |
Hi Thomas,
the package you'
Hi Thomas,
the package you're looking for is in the OSS repository of openSUSE, that can be added using YaST -> Software -> Installation sources (maybe the names are slightly different, I'm translating what I read in the Italian version). The OSS repository is added by default during the installation, and you should already see it in the list. To install the package, use the installer or simply type (as root) in a terminal: zypper in lib-qt4-devel For your convenience, on openSUSE, you can search for packages using: - http://software.opensuse.org/search - selecting the openSUSE logo (chameleon) in the search bar of firefox - if you need to search also among community packages (codecs, ...): http://packages.opensuse-community.o...sp?searchTerm= With kind regards, Alberto |
Still working on paraView reco
Still working on paraView recompile for SUSE1.5 using QT4.4. Got compilation failure (see below). Any additional suggestions.
I followed suggestions below: - In CMakeLists.txt comment the line: # MESSAGE(SEND_ERROR "Qt ${QTVERSION} not supported. Please use Qt 4.3 (you may need to clean your dirtied cache).") - Installed libqt4-devel package (I installed using software download from repository OSS. It installed a lot of other software along with libqt4-devel) - Removed '~/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms' directory - ran 'buildParaView3.3-cvs' to compile Paraview I got a compilation failure with messages below: Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/kosvic/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/kosvic/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc CMake Error: CMake was unable to find a build program corresponding to "Unix Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool. CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_C_COMPILER_ENV_VAR CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_C_COMPILER CMake Error: Could not find cmake module file:/home/kosvic/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFi les/CMakeCCompiler.cmake CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_CXX_COMPILER_ENV_VAR CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_CXX_COMPILER CMake Error: Could not find cmake module file:/home/kosvic/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFi les/CMakeCXXCompiler.cmake CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage -- Configuring done |
Thomas,
Did you source the
Thomas,
Did you source the bashrc file as said in the README? It seems cmake is not found in your system, but you should have it in ~/OpenFOAM/ThirdParty/cmake-2.4.6 In my laptop: jose@laptop:~/OpenFOAM/ThirdParty> which cmake /home/jose/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake Run foamInstallationTest to check if your system is correctly configured. Regards, Jose Santos |
I finally compiled par
I finally compiled paraview and paraFoam reader successfully myself on openSUSE 11.0 with Qt 4.4 (the version provided by openSUSE) following Mattijs and Niklas guidelines. Unfortunately I didn't find out what was causing the truncation to integer I previously reported. Alberto |
Alberto,
Did your compiled
Alberto,
Did your compiled version of paraFoam (SUSE 11 and QT 4.4) properly open up, find a reader, and allow a display of the grid and velocity vectors for the icoFoam cavity case in the Tutorials? What were the steps you did that finally allowed the compilation that you were unsuccessful at before? Thanks, Tom Kosvic |
Hello Thomas,
I didn't test
Hello Thomas,
I didn't test it on the cavity case before you asked me. I used a 2D mesh imported generated in gambit and it worked, as it works properly with the rhoPorousSimpleFoam tutorials. I've just tried it with the cavity case, I still have the truncation problem (no geometry nor data shown). So the problem seems only partly fixed. :-( The compilation process is the one explained in the readme file. The only difference is a patch released by openSUSE. Regards, Alberto |
I'm getting this error on Ubun
I'm getting this error on Ubuntu Hardy and Fedora 8. From the answers above I'm not sure what the solution is (just recompile paraview?). Is there a way to get it working, without recompiling paraview? I don't own a fast Linux machine currently and therefore recompiling is slow http://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif On which system were the binaries tested?
foamToVTK works on Fedora, but
foamToVTK works on Fedora, but not on Ubuntu, there I get:
From function Foam::cwd() in file Unix.C at line 199. wtf? |
The messages comes from the ge
The messages comes from the getcwd system call failing which can happen if:
- the current directory does not exist anymore (e.g. deleted from another window) - the directory name is longer than 255 characters. Any chance of these happening? |
Thx I deleted the directory, t
Thx I deleted the directory, then recreated it. I had to do
cd <somewhere> and then back cd into the dir i was before, then it worked |
OpenFOAM is solving the cavity
OpenFOAM is solving the cavity tutorial as expected but CMake variables are not set when running "buildParaView3.3-cvs". Anyone who can help me please.
--- csvs@linux-pk1o:~/OpenFOAM/ThirdParty> ../OpenFOAM-1.5/bin/./foamSystemCheck Checking basic system... ----------------------------------------------------------------------- Shell: /bin/bash Host: linux-pk1o OS: Linux version 2.6.25.5-1.1-default User: csvs System check: PASS ================== Continue OpenFOAM installation. csvs@linux-pk1o:~/OpenFOAM/ThirdParty> ../OpenFOAM-1.5/bin/./foamInstallationTest Executing ../OpenFOAM-1.5/bin/./foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux-pk1o OS: Linux version 2.6.25.5-1.1-default ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/csvs/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/csvs/OpenFOAM/csvs-1.5 yes no $WM_THIRD_PARTY_DIR /home/csvs/OpenFOAM/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/csvs/OpenFOAM/OpenFOAM-1.5 yes yes yes $FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes $FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no $WM_DIR /home/csvs/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes $FOAM_USER_LIBBIN ...penFOAM/csvs-1.5/lib/linux64GccDPOpt yes yes no $MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc gzip 1.3.12 /usr/bin/gzip tar 1.19 /bin/tar icoFoam 1.5 .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_linux-pk1o Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. done. csvs@linux-pk1o:~/OpenFOAM/ThirdParty> cd $FOAM_INST_DIR/ThirdParty csvs@linux-pk1o:~/OpenFOAM/ThirdParty> rm -rf ParaView3.3-cvs/platforms csvs@linux-pk1o:~/OpenFOAM/ThirdParty> buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/csvs/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/csvs/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc CMake Error: CMake was unable to find a build program corresponding to "Unix Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool. CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_C_COMPILER_ENV_VAR CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_C_COMPILER CMake Error: Could not find cmake module file:/home/csvs/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFi les/CMakeCCompiler.cmake CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_CXX_COMPILER_ENV_VAR CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly. Missing variable is: CMAKE_CXX_COMPILER CMake Error: Could not find cmake module file:/home/csvs/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFi les/CMakeCXXCompiler.cmake CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage -- Configuring done /home/csvs/OpenFOAM/OpenFOAM-1.5/bin/tools/buildParaViewFunctions: line 206: make: command not found done --- Best regards, Christian Lindbäck |
From the last line:
/home/c
From the last line:
/home/csvs/OpenFOAM/OpenFOAM-1.5/bin/tools/buildParaViewFunctions: line 206: make: command not found do you have installed "make"? |
Thank you. Embarrasing, I assu
Thank you. Embarrasing, I assumed that make was installed from start in OpenSUSE 11.
Now things are working. However, when running paraFoam I don't see a thing of my geometry. And there are no error messages. In the information it says that my domain extends from 0 to 0 in all directions. Something is wrong and I have no clue how to solve the problem. When using foamToVTK first I can see my geometry however. |
Hi Christian
I am new to Op
Hi Christian
I am new to OpenFOAM and Fedora. While trying to install ParaFoam I got the same problem that ypou had posted on Sept 15. But i have no idea how to install make file. Can you please help. |
Use YaST (it is in the menu in
Use YaST (it is in the menu in the GUI of your OS I hope) and go to where you install software. The search for "make" and choose to install the package.
If you use Fedora,as a root us
If you use Fedora,as a root user, run the following command
yum -y install make |
All, looks like this thread ha
All, looks like this thread has become a parafoam and paraview process discussion so:
Has anyone gotten the binary distributions in openfoam1.5 of parafoam and paraview to run properly? By run properly, I mean can you see the grid, velocity vectors, pressure profiles etc for the cavity case discussed as 1st step in the tutorials? By run properly, I mean also that paraview found a proper reader and that the viewing was done without foamToVTK conversion. If you have had success using the binary distributions of parafoam and paraview let us all know what special steps you did. I have SUSE with QT4.4 and Fedora and have not had luck running parafoam and paraview with either of these. If no one has had any success then I will move to re-compiling these processes. Thanks much, Tom Kosvic |
Thomas,
I got it to run aft
Thomas,
I got it to run after a bit of cursing... We run SUSE 10.1 and had to load the qt 4.3.5 to to get it to work. We used an rpm install we found at openSUSE (we found the right ones here http://download.opensuse.org/reposit...SLE_10/x86_64/ ) I had to be careful on what was in the library path, but once a reference to an older version of QT was removed, it worked just fine. Mike Rangitsch |
I've installed the proposed Qt
I've installed the proposed Qt 4.3.5 locally, configured and built pview3.3-cvs and the vtkPV3FoamReader without problems on suse 11, 32 bit.
Running paraFoam on a tutorial case inside the case directory gives me a small window asking me to define the reader for tutorialCase.OpenFOAM Can somebody please help me and explain why does it do so, when the reader for .OpenFOAM files is compiled without problems? And to make it more confusing: one of the offered options is : "OpenFOAM files". |
