Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
gradientEnthalpy and wallHeatTransfer
Old   July 9, 2009, 07:31
Default gradientEnthalpy and wallHeatTransfer
Markus Rehm
markusrehm is on a distinguished road
I am having problems to use the gradientEnthalpy BC for buoyantSimpleFoam in the hotRoom case at the walls. For 0/T I applied it as follows:
fixedWalls
        type            gradientEnthalpy;
        gradient        uniform -1000.0;
It produces a memory error in the hEqn. On the other hand for the wallHeatTransfer BC everything works well.
It doesn't seem to be a problem of the thermos - so much I found out.
In gradientEnthalpyFvPatchScalarField.C:111 Tw.evaluate(); is calling its own updateCoeffs() function again and again.
Any solution to this?
I use the 1.5.x git version. See the output below.
Regards, Markus.
rem@IEC126:~/OpenFOAM/rem-1.5.x/run/buoyantSimpleFoam/hotRoom> buoyantSimpleFoam
|  \\    /   O peration     | Version:  1.5.x                                 |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
Exec   : buoyantSimpleFoam
Date   : Jul 09 2009
Time   : 13:28:26
Host   : IEC126
PID    : 529
Case   : /home/rem/OpenFOAM/rem-1.5.x/run/buoyantSimpleFoam/hotRoom
nProcs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading thermophysical properties
Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0.85;
    alphah          1;
    alphak          1;
    alphaEps        0.76923;
Calculating field g.h
Creating field pd
Starting time loop
Time = 1
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 8.16329e-07, No Iterations 6
DILUPBiCG:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 8.16329e-07, No Iterations 6
Speicherzugriffsfehler
markusrehm is offline   Reply With Quote
Old   July 12, 2009, 14:05
Henrik Rusche
henrik is on a distinguished road
Dear Markus,
The *Enthalpy-boundary conditions are not meant to be used on temperature-fields.
You can understand the internal workings by having a look into $FOAM_SRC/thermophysicalModels/basic/lnInclude/basicThermo.C
Try putting a fixedGradient boundary condition on T.
Henrik
henrik is offline   Reply With Quote
Old   July 13, 2009, 04:06
Markus Rehm
Thanks Henrik,
I will have a deeper look. Markus
