Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
SampleSurf interpolatedPlane
Old   May 5, 2008, 04:39
Default Hi! I'm using OpenFOAM V 1.
Maka Mohu
maka is on a distinguished road
Hi!
I'm using OpenFOAM V 1.3.
I attach below a modified cavity case.
If you run sampleSurf with:
interpolatedPlane
name interpolatedPlane;
basePoint (0.05 0.05 0.0075);
//normalVector (0 0.0011 0.0075); //y=(0.015/0.1)*0.0075;
normalVector (0 0 1);
triangulate false;
It will produce sampleSurfaces/0.5/U_interpolatedPlane.raw that looks correct (contains 21*21=441 value, read the header).
BUT if you modify the sampleSurfDict to:
interpolatedPlane
//normalVector (0 0 1);
triangulate false;
It will produce values that are > 441 which seems not correct to me. This is because any plane surface can maximally cut a hexagonal cell in 4 edges generating 4 vertices as a result the max no of value should also be 21*21=441. Thanks.
Best regards,
Maka
maka is offline   Reply With Quote
Old   May 5, 2008, 04:50
Default this message is a duplicate by
Maka Mohu
this message is a duplicate by mistake. see link
SampleSurf interpolatedPlane maka OpenFOAM Bugs 0 May 5, 2008 04:42
