Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Valgrind claims invalid free when running icoFoam from OpenFOAM 1.6-ext
Old   March 25, 2011, 06:34
Default Valgrind claims invalid free when running icoFoam from OpenFOAM 1.6-ext
Andrew Ryan
andrewryan is on a distinguished road
Dear Foamers
Checking the memory management of my own application I ran into an invalid free, which I could not find anywhere in my code. Turns out that valgrind complains about invalid free in solvers like icoFoam, here is the complete output:
==4973== Invalid free() / delete / delete[]
==4973==    at 0x4C27D71: free (vg_replace_malloc.c:366)
==4973==    by 0x7408A0A: free_mem (in /lib/libc-2.12.1.so)
==4973==    by 0x74085A1: __libc_freeres (in /lib/libc-2.12.1.so)
==4973==    by 0x4A2366B: _vgnU_freeres (vg_preloaded.c:62)
==4973==    by 0x730F4A4: exit (exit.c:93)
==4973==    by 0x72F4D94: (below main) (libc-start.c:258)
==4973==  Address 0x404dc50 is not stack'd, malloc'd or (recently) free'd
==4973==
==4973==
==4973== HEAP SUMMARY:
==4973==     in use at exit: 300 bytes in 11 blocks
==4973==   total heap usage: 202,813 allocs, 202,803 frees, 99,653,936 bytes allocated
==4973==
==4973== LEAK SUMMARY:
==4973==    definitely lost: 60 bytes in 1 blocks
==4973==    indirectly lost: 240 bytes in 10 blocks
==4973==      possibly lost: 0 bytes in 0 blocks
==4973==    still reachable: 0 bytes in 0 blocks
==4973==         suppressed: 0 bytes in 0 blocks
==4973== Rerun with --leak-check=full to see details of leaked memory
==4973==
==4973== For counts of detected and suppressed errors, rerun with: -v
==4973== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 4 from 4)
Steps to reproduce: Install valgrind and run valgrind icoFoam in the cavity case in $FOAM_TUTORIALS/incompressible/icoFoam
The same also seems to happen with other solver such as potentialFoam. This looks like a bug to me.
andrewryan is offline   Reply With Quote
Old   March 25, 2011, 07:07
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I don't get this error, although I remember getting some like it before and it's something to do with glibc, maybe update that?
Looks identical to this: http://sourceware.org/bugzilla/show_bug.cgi?id=10610
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   March 27, 2011, 12:59
Hrvoje Jasak
This is all in POSIX.C with functions like
Foam::userName() (POSIX.C:123)
getpwuid_r (in /lib/libc-2.9.so)
getpwuid (in /lib/libc-2.9.so)
and it is inconsequential. I have recently cleaned up bugs in HashTables as well, but it looks like this is at the level of OS interface and I cannot be bothered to chase it.
If you clean up POSIX.C to do the deletes as needed I will pick up the code, merge it and buy you a beer!
Deal?
Hrv
Hrvoje Jasak
Old   March 30, 2011, 08:00
Is the invalid free not a separate error from the memory leak?
I also don't see how Foam::userName() (POSIX.C:123) is at fault, there's no dynamic memory allocation in there.
bugs memory extended
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
