Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
SonicFoam forwardStepTutorial doesnbt complete the run
Old   June 10, 2007, 14:44
Default Description: The forwardStep t
Alberto Passalacqua
Description: The forwardStep tutorial of sonicFoam doesn't complete the simulation and aborts with the error:
Courant Number mean: -8.55342e+25 max: 1.66084e+28
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0xffffe420]
#3 Foam::DILUPreconditioner::DILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::Istream&)
#4 Foam::lduMatrix::preconditioner::addasymMatrixCons tructorToTable<foam::dilupreco nditioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&)
#5 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&)
#6 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const
#7 Foam::fvMatrix<foam::vector<double> >::solve(Foam::Istream&)
#8 Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)
#9 main
#10 __libc_start_main
#11 __gxx_personality_v0 at ../sysdeps/i386/elf/start.S:122
Increasing the time step to 0.003s circumvents the problem.
Solver/Application: sonicFoam
Source file:
Testcase: forwardStep tutorial for sonicFoam
Platform: All
Version: 1.4
Notes: The issue was found by Florian Fruth. See http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/4657
Regards,
Alberto
Alberto Passalacqua
Old   June 10, 2007, 15:35
Default As suggested by Hrvoje, the so
Alberto Passalacqua
As suggested by Hrvoje, the solution consists in setting the outlet BC to zeroGradient for T and U.
I attach the corrected tutorial case.
forwardStep.zip
Regards,
A.
Alberto Passalacqua
FOAM The Complete Guide nico765 OpenFOAM Running, Solving & CFD 4 December 6, 2013 10:26
mesh a complete plane horsee FLUENT 13 April 17, 2010 20:20
how to view the complete results shokry FLOW-3D 5 February 3, 2009 13:56
Complete mixing Jamie Main CFD Forum 0 October 6, 2008 10:47
Simple Q. How to complete a Case? W.A. Siemens 3 April 23, 2006 19:41
