Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug in wall function
Old   June 6, 2007, 11:10
Default There is a minor bug in the im
Rolando Maier
rolando is on a distinguished road
There is a minor bug in the implementation of the wall function.
The production term is calculated as:
G = nu_t * dUdY * Cmu25 * sqrt(k) / (kappa * y)
As the production is defined as:
G = tau_wall * dUdY * (Cmu25 * sqrt(k) / (kappa * y)
and:
tau_wall = (nu + nu_t) * dUdY
nu_t should be replaced by (nu + nu_t)
In a wide range of the application of the wall function this doesnīt matter as nu << nu_t.
But in the lower wall function range nu_t ~ nu and it can have an influence.
Rolando
rolando is offline   Reply With Quote
Old   June 6, 2007, 12:38
Default We have been investigating thi
henry is on a distinguished road
We have been investigating this recently. The current implementation using nu_t is consistent with the production term in the k-epsilon model which also uses nu_t rather than nu_eff. We understand that most people use nu_eff in the production term in the wall-functions and we will change OpenFOAM to conform. We also understand that in the latest version of Fluent nu_eff rather than nu_t is now used in the production term in the k-epsilon and other two-equation models although no justification is given for this. Do you have any thoughts on this matter?
Henry
henry is offline   Reply With Quote
Old   June 6, 2007, 15:55
Default In the inner flow field of a f
Rolando Maier
In the inner flow field of a fully turbulent flow there should be no difference between nut and nuEff, as nut >> nu.
At the wall the idea of a flow with no curvature, respectively constant shear stress between the wall point and the first field point is used. This is a Couette flow. For this flow the production of turbulent kinetik energy is:
P = -<u_t*u_n> * dU_t/dn
The reynolds stress is equivalent the wall shear stress (constant shear stress):
-<u_t*u_n> = tau_w / rho
The derivative at the first field point is built from the logarithmic velocity profile:
dU_t/dn = u_tau / (kappa * n) = pow(Cmu, 0.25) * sqrt(k) / (kappa * n)
=> P = tau_w / rho * pow(Cmu, 0.25) * sqrt(k) / (kappa * n)
tau_w = nuEff * dU_t/dn
So by the idea of using the couette flow, the usage nuEff rather than nut in the wall neat domain is justifiable.
Rolando
Old   June 7, 2007, 05:35
Default Do you think the production te
Do you think the production term in the two-equation models should be made consistent, i.e. use nuEff rather than nut? If so what is the justification and why is it rarely done that way (apart from the latest Fluent that is)?
Henry
Old   June 7, 2007, 09:07
Default In the literature the wall pro
Rolando Maier
In the literature the wall production of k is mostly:
P_w = tau_wall * (dU/dy)
tau_wall is a function of nu_eff rather than nu_t.
This is also done in OpenFOAM at one place. There the wall function calculates the turbulent wall viscosity as:
nu_t_wall = tau_wall / (dU / dy) - nu_wall
For the calculation of P_w, tau_wall should be reconstructed in this same way, for consistency reasons. This means, that (nu_t_wall + nu_wall), rather than nu_t_wall should be used for the calculation of the wall production of k.
Below there is a plot of the ratio of the wall productions calculated by nu_eff and nu_t.
The abscissa shows the wall distance in the dimensionless formulation of y+. It is plotted from 30 (the lower end of the logarithmic region) to 1000.
The ordinate shows the ratio of the two formulations.
You can see, that at the lower end of the scope (y+ ~ 30) , there is a large difference of nearly 100%. At the other end the difference is of about 2%, which might be negligible, as the "error" by not simulating the wall near domain might be larger.
Rolando
Old   June 7, 2007, 09:16
Default I understand the arguments abo
I understand the arguments about the wall production, my question relates to the production term in the two-equations models independent of the wall treatment, i.e. in the bulk flow.
Henry
Old   June 7, 2007, 09:30
Default Independent of the wall treatm
Rolando Maier
Independent of the wall treatment, Iīm familiar with the formulation P = nu_t * S^2 as it is implemented in OpenFOAM.
The latest fluent manual I own, is the fluent 6.2 (which one is the latest one?).
There it is still done in this way. If in a newer release it is done in an other way, I donīt know why.
Rolando
Old   June 8, 2007, 04:51
Default Just a comment about the turbu
Michele
michele is on a distinguished road
Just a comment about the turbulence production in the k equation.
The turbulent production represents the rate at which kinetic energy is transferred from the mean flow to the turbulence, and is defined as
Pk=tau_ij S_ij,
where tau_ij represents the Reynolds stress tensor and S_ij the mean strain-rate tensor.
The Reynolds stress tensor, under the Boussinesq constitutive model (for incompressible flows), is
tau_ij=2 nu_t S_ij - 2/3 k delta_ij
(delta_ij is the Kronecker diagonal tensor).
Substituting and taking into account for the incompressibility (delta_ij S_ij=0), the production term is then
Pk=nu_t S^2,
as correctly defined in OpenFOAM.
Michele
michele is offline   Reply With Quote
How can I add a new wall function imano OpenFOAM Running, Solving & CFD 14 September 17, 2015 08:53
wall function for low Re M. Essuri FLUENT 2 December 18, 2006 03:11
wall function Alex CFX 9 May 19, 2005 10:05
Does RSM use wall function? Sam Main CFD Forum 4 March 2, 2005 23:58
Wall function Min-Hua Wang CFX 4 July 5, 2002 12:13
