May 8, 2007, 09:07 |
Description:
The second time-
Rep Power: 22 |
Description:
The second time-step of a run using the CrankNicholsonDdtScheme is not exactly correct. The attached fix resolves this problem and improves the handling of restarts and supports the change from other schemes to the CrankNicholsonDdtScheme scheme during a run. Solver/Application: All using this second-order temporal derivative. Source file: OpenFOAM-1.4/src/finiteVolume/finiteVolume/ddtSchemes/CrankNicholsonDdtScheme/CrankNicholsonDdtScheme.[HC] Platform: All. Version: 1.4 Fix: CrankNicholsonDdtScheme.H CrankNicholsonDdtScheme.C |
May 15, 2007, 05:00 |
Iam installing OpenFOAM SW on
Suresh kumar Kannan
Rep Power: 17 |
Iam installing OpenFOAM SW on a 64bit AMD machine with 2 processors. I did all the steps suggested by Hrvoje Jasak and everything worked.
(I mean the only test cases). I must say that I have to add different PATH for LIBRARY definitions to get the libraries get linked.Iam installing the SW for a user. I must say that I have NOT yet compiled the program on my machine till now.Iam installing OpenFOAM-1.4 on my machine.I want to know is there any tests which I can do to test the installation of SW? I did the the following test from icoFoam directory: blockMesh . cavity icoFoam . cavity Both worked without error. I have another question regarding the startup of FoamX command. When I start the script I get the following error: $strace FoamX + jdkhome=/usr/java/jdk1.4 + '[' '!' -z /home/l_kumar/OpenFOAM/linux64/j2sdk1.4.2_05 ']' + jdkhome=/home/l_kumar/OpenFOAM/linux64/j2sdk1.4.2_05 + '[' -z /home/l_kumar/OpenFOAM/linux64/j2sdk1.4.2_05 ']' + '[' '!' -x /home/l_kumar/OpenFOAM/linux64/j2sdk1.4.2_05/bin/java ']' + '[' -z /home/l_kumar/OpenFOAM/jobControl ']' + '[' '!' -d /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX ']' + '[' '!' -r /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/FoamXClient.cfg ']' ++ getValue /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/FoamXClient.cfg org.omg.CORBA.ORBInitialHost +++ grep '^[ \t]*org.omg.CORBA.ORBInitialHost[ \t]*=' /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/FoamXClient.cfg +++ sed -e 's/^[ \t]*org.omg.CORBA.ORBInitialHost[ \t]*=//' +++ head -1 ++ val= ++ '[' -z '' ']' ++ return 1 + HOSTNAME= + '[' 1 -ne 0 ']' ++ uname -n + HOSTNAME=pc4989 ++ getValue /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/FoamXClient.cfg org.omg.CORBA.ORBInitialPort +++ grep '^[ \t]*org.omg.CORBA.ORBInitialPort[ \t]*=' /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/FoamXClient.cfg +++ sed -e 's/^[ \t]*org.omg.CORBA.ORBInitialPort[ \t]*=//' +++ head -1 ++ val= ++ '[' -z '' ']' ++ return 1 + HOSTPORT= + '[' 1 -ne 0 ']' + HOSTPORT=1234 + argPort= + argHost= + args= + '[' '' ']' + XHB_PID= + trap cleanup 0 2 3 15 + '[' '' -o '' ']' + '[' -r /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/ns.ref ']' + killFoamX + runFoamXHB + XHB_PID=2142 + '[' 2142 ']' + '[' '!' -f /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/ns.ref ']' + sleep 1 Starting NameServer with inet:pc4989:1234 ... nsd: error while loading shared libraries: libcrypto.so.0.9.7: cannot open shared object file: No such file or directory + '[' '!' -f /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/ns.ref ']' + sleep 1 + '[' '!' -f /home/l_kumar/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/ns.ref ']' . . . The above message repeats many times. I would like to know how I can overcome this error and what is the contents of the file "ns.ref". I donot have this file in the above directory. I will appreciate very much your hrlp. Regards, Kumar |
May 18, 2007, 13:01 |
Hello Henry,
If I'm only us
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Hello Henry,
If I'm only using icoFoam and interFoam (both in parallel), is there any way I can avoid recompiling everything? What libraries do need to be recompiled after using your updated CrankNicholsonDdtScheme.* files. Thanks! |
May 18, 2007, 14:35 |
All the ddt functions are run-
Rep Power: 22 |
All the ddt functions are run-time selectable and hence built into the finiteVolume library so you only need to recompile that library.
Henry |
May 22, 2007, 09:23 |
Hello Henry,
I download your
Cedric DUPRAT
Rep Power: 17 |
Hello Henry,
I download your last version of CrankNicholsonDdtScheme.* and copy it in the folder: OpenFOAM/OpenFOAM-1.3/src/finiteVolume/finiteVolume/ddtSchemes/CrankNicholsonDdt Scheme/. then I compiles with wmake in OpenFOAM/OpenFOAM-1.3/src/finiteVolume following your advices to pUI| but, I have an error message : " (...) lnInclude/CrankNicholsonDdtScheme.C:120: error: 'const class Foam::Time' has no member named 'startTimeIndex' lnInclude/CrankNicholsonDdtScheme.C:121: error: 'const class Foam::Time' has no member named 'startTimeIndex' lnInclude/CrankNicholsonDdtScheme.C:131: error: 'store' is not a member of 'Foam::regIOobject' lnInclude/CrankNicholsonDdtScheme.C:149: error: 'store' is not a member of 'Foam::regIOobject' make: *** [Make/linuxGcc4DPOpt/pressureTransmissiveFvPatchScalarField.o] Error 1 " I use OF v 1.3, is it the reason of the problem ? or maybe I made something wrong ... OUPS !! I've got a doubt now ... is your modifications only for v 1.4 of OF ? Thanks Cedric |
May 22, 2007, 11:52 |
Yes the modification is for Op
Rep Power: 22 |
Yes the modification is for OpenFOAM-1.4
Display Modes | |
Minor bug in cellQualityC | lr103476 | OpenFOAM Bugs | 5 | February 13, 2009 07:28 |
Minor buoyancy problem in Phoen2007 | patti | Phoenics | 3 | December 1, 2007 18:43 |
Minor compilation problem with Gcc42 | schmidt_d | OpenFOAM Bugs | 1 | May 9, 2007 13:11 |
Minor loss coefficients | Nick | Main CFD Forum | 3 | October 7, 2004 11:28 |
minor loss k values | clifford bradford | Main CFD Forum | 1 | August 2, 2000 16:58 |
