Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
TwoPhaseEulerFoam and InletOutlet BC
Old   January 29, 2007, 04:57
Default I apply the inletOutletBoundar
Rasmus Hemph
hemph is on a distinguished road
I apply the inletOutletBoundary condition on the outlet, with a zero inlet velocity for the fluid, but still get influx through some faces. Should this be possible?
A picture of the (converged) flow field can be seen here:
http://www.tfd.chalmers.se/~md8hemra/images/outflow.png
The Ub-velocity field on the influx faces is zero in the output file as they should, but the corresponding phib-field is not equal to zero. It appears that phib and Ub are not connected on the inflow faces.
A test case can be downloaded from
http://www.tfd.chalmers.se/~md8hemra...stCase2.tar.gz
The flow behavior appears after about 1.5 seconds.
hemph is offline   Reply With Quote
Inletoutlet rengu OpenFOAM Running, Solving & CFD 8 December 25, 2015 15:44
InletOutlet condition with arbitrary direction matteoc OpenFOAM Running, Solving & CFD 8 May 31, 2011 06:49
Cyclic inletoutlet with icoFoam sripplinger OpenFOAM Running, Solving & CFD 5 November 8, 2008 04:48
Velocity Jump at InletOutlet cliffoi OpenFOAM Running, Solving & CFD 0 September 8, 2008 05:34
TwoPhaseEulerFoam and InletOutlet boundary condition hemph OpenFOAM Running, Solving & CFD 10 January 29, 2007 09:47
