Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Discontinuity in Paraview
Old   May 28, 2012, 04:41
Default Discontinuity in Paraview
Jonathan
Mkoll is on a distinguished road
Hi everyone,
First post, i hope you can help me
I'm french so, sorry if i make too big mistakes^^
So, i have a discontinuity in my simulation (using twoLiquidMixingFoam) when i try to simulate an avalanche interacting with an obstacle.
You can see that with attached files (bug, bug2, bug3).
I hope you can tell me how to fix that.
I'm using OpenFOAM 1.6.
I also join blockMeshDict and boundaries.
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(20 0 0)
(20.4 0 0)
(38 0 0)
(0 0.6 0)
(20 0.6 0)
(20.4 0.6 0)
(38 0.6 0)
(0 10 0)
(20 10 0)
(20.4 10 0)
(38 10 0)
(0 0 0.1)
(20 0 0.1)
(20.4 0 0.1)
(38 0 0.1)
(0 0.6 0.1)
(20 0.6 0.1)
(20.4 0.6 0.1)
(38 0.6 0.1)
(0 10 0.1)
(20 10 0.1)
(20.4 10 0.1)
(38 10 0.1)
blocks
hex (0 1 5 4 12 13 17 16) (125 10 1) simpleGrading (1 1 1)
hex (2 3 7 6 14 15 19 18) (125 10 1) simpleGrading (1 1 1)
hex (4 5 9 8 16 17 21 20) (125 50 1) simpleGrading (1 1 1)
hex (5 6 10 9 17 18 22 21) (25 50 1) simpleGrading (1 1 1)
hex (6 7 11 10 18 19 23 22) (125 50 1) simpleGrading (1 1 1)
edges
patches
wall leftWall
(0 12 16 4)
(4 16 20 8)
wall rightWall
(7 19 15 3)
(11 23 19 7)
(8 20 21 9)
(9 10 22 21)
(10 11 23 22)
wall lowerWall
(0 1 13 12)
(1 5 17 13)
(5 6 18 17)
(2 14 18 6)
(2 3 15 14)
(8 20 21 9)
(9 10 22 21)
(10 11 23 22)
mergePatchPairs
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
4
leftWall
type wall;
nFaces 60;
startFace 32155;
rightWall
type wall;
nFaces 60;
startFace 32215;
lowerWall
type wall;
nFaces 295;
startFace 32275;
defaultFaces
type empty;
nFaces 32500;
startFace 32845;
Thanks,
Jonathan
Mkoll is offline   Reply With Quote
Old   May 28, 2012, 06:29
Martin
MartinB will become famous soon enough
Hi Jonathan,
you should refine your mesh around the obstacle. Have a look at the different cell sizes there ("Surface with edges" visualization in Paraview).
You can do this by using simpleGrading parameters in the blocks definition part like this:
FoamFile
 version 2.0;
 format ascii;
 class dictionary;
 convertToMeters 1;
 vertices
 (0 0 0)
 (20 0 0)
 (20.4 0 0)
 (38 0 0)
 (0 0.6 0)
 (20 0.6 0)
 (20.4 0.6 0)
 (38 0.6 0)
 (0 10 0)
 (20 10 0)
 (20.4 10 0)
 (38 10 0)
 (0 0 0.1)
 (20 0 0.1)
 (20.4 0 0.1)
 (38 0 0.1)
 (0 0.6 0.1)
 (20 0.6 0.1)
 (20.4 0.6 0.1)
 (38 0.6 0.1)
 (0 10 0.1)
 (20 10 0.1)
 (20.4 10 0.1)
 (38 10 0.1)
 blocks
 hex (0 1 5 4 12 13 17 16) (125 10 1) simpleGrading (0.05 1 1)
 hex (2 3 7 6 14 15 19 18) (125 10 1) simpleGrading (20 1 1)
 hex (4 5 9 8 16 17 21 20) (125 50 1) simpleGrading (0.05 1 1)
 hex (6 7 11 10 18 19 23 22) (125 50 1) simpleGrading (20 1 1)
 edges
 patches
 wall leftWall
 (0 12 16 4)
 (4 16 20 8)
 wall rightWall
 (7 19 15 3)
 (11 23 19 7)
 (8 20 21 9)
 (9 10 22 21)
 (10 11 23 22)
 wall lowerWall
 (0 1 13 12)
 (1 5 17 13)
 (5 6 18 17)
 (2 14 18 6)
 (2 3 15 14)
 //(8 20 21 9)
 //(9 10 22 21)
 //(10 11 23 22)
 mergePatchPairs
Martin
MartinB is online now   Reply With Quote
Old   May 28, 2012, 07:22
Jonathan
Hi Martin
Thanks for answering.
I tried with your blockMesh
It seems to be a little better ?
I attached some screenshots.
Jonathan
Old   May 28, 2012, 15:55
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
As already pointed out by Martin, it seems like you have a way too big discontinuity in your mesh. I would suggest you to post a picture that depicts your mesh around the obstacle.
lovecraft22 is offline   Reply With Quote
Old   May 28, 2012, 16:38
Jonathan
Hi lovecraft22
I hope it's what you ask.
Old   May 28, 2012, 16:44
lore
Yes it is. As you can see you have a big difference in your cells, as a matter of fact it the picture you attached the cells above the obstacle cannot be seen as the blue lines are too close to each other. So you can either make a coarser mesh in that region or make a finer mesh in the surrounding regions.
Old   May 29, 2012, 01:32
Jonathan
Hi lovecraft22
The goal was to make finer the mesh around the obstacle.
I'll try with the same precision everywhere.
Thanks,
Jonathan
Old   May 29, 2012, 03:11
lore
It can (and should) be finer around the obstacle but the transition between one mesh level and the one close to it should be smooth.
[General] Paraview nice animation PyGloo ParaView 4 June 7, 2012 12:34
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
Paraview not found fusij OpenFOAM Installation 2 January 1, 2011 20:44
[OpenFOAM] Distributed ParaView and PV3FoamReader micalil ParaView 4 July 1, 2010 05:09
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
