Feature proposal: Application level profiling |
April 28, 2009, 15:24 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
At first: Yes I know how to compile a profile version of OF, but sometimes I find the amount of information there a bit overwhelming when I ask myself simple questions like: "The pressure equation seems to eat most of the CPU-time, but how much exactly" and don't want to know every detail
Second: I know this is not a bug, but I don't know what would be the appropriate forum for this Attached there is an archive with the example implementation. The attached archive can be used as a separate library (which requires modifications of the solver) or compiled into libOpenFOAM.so. The latter adds some data-structures for Profiling. The profiling information will be automatically written into a file uniform/profilingInfo at every time-step for which data is written to disk. The profiling information is basically how much time was spent in a section, how often it was called and how much time was spent in the 'child' sections. The sections have to be marked with the addProfile-Macro (closed by an optional endProfile). The enclosed patch automatically does this for the linear solvers. So if running an unmodified interFoam on the damBreak case the data would look like this after being processed with the enclosed Python-script, the raw data looks more foamish): Code:
| parent (total ) - self | calls total self ------------------------------------------------------------------------------------------ "application::main" | 100.0% ( 67.5%) - 67.5% | 1 69.57s 46.93s |-"lduMatrix::solver_pcorr" | 0.0% ( 0.0%) - 100.0% | 1 0.00055s 0.00055s |-"MULES::explicitSolve" | 8.5% ( 8.5%) - 100.0% | 2092 5.946s 5.946s |-"lduMatrix::solver_pd" | 23.2% ( 23.2%) - 100.0% | 3138 16.12s 16.12s |-"writing" | 0.8% ( 0.8%) - 100.0% | 20 0.5808s 0.5808s (please excuse the misalignment, the board doesn't seem to think that fixed-length-font is appropriate for Code) The "raw" data is on the right on the left there are the percentages calculated from that. In this example there is only one "parent" and three children. A slightly modified interFoam (see other patch) would generate this profile Code:
| parent (total ) - self | calls total self ---------------------------------------------------------------------------------------------- "application::main" | 100.0% ( 0.0%) - 0.0% | 1 69.82s 0.0021s |-"init" | 0.1% ( 0.1%) - 93.1% | 1 0.06371s 0.05934s |-"correctPhi" | 6.9% ( 0.0%) - 84.9% | 1 0.004364s 0.003703s |-"lduMatrix::solver_pcorr" | 15.1% ( 0.0%) - 100.0% | 1 0.000661s 0.000661s |-"timeLoop" | 99.9% ( 3.9%) - 4.0% | 1046 69.75s 2.757s |-"gammaEqnSubCycle" | 25.0% ( 5.7%) - 22.9% | 1046 17.46s 3.996s |-"gammaEqn" | 77.1% ( 10.7%) - 55.4% | 2092 13.46s 7.461s |-"MULES::explicitSolve" | 44.6% ( 8.6%) - 100.0% | 2092 6.002s 6.002s |-"UEqn" | 9.4% ( 9.4%) - 100.0% | 1046 6.572s 6.572s |-"pEqn" | 60.9% ( 0.3%) - 0.5% | 3138 42.46s 0.2084s |-"pEqn - pre" | 34.7% ( 21.1%) - 100.0% | 3138 14.72s 14.72s |-"pEqn - Corrector" | 47.3% ( 5.7%) - 19.9% | 3138 20.08s 3.993s |-"lduMatrix::solver_pd" | 80.1% ( 23.0%) - 100.0% | 3138 16.08s 16.08s |-"pEqn - post" | 17.6% ( 10.7%) - 100.0% | 3138 7.456s 7.456s |-"writing" | 0.7% ( 0.7%) - 100.0% | 20 0.5095s 0.5095s To install the profiling support into OF use the addProfilingToRelease.sh-script enclosed in the tar and recompile the installation (this works for 1.5(.x). 1.4.1 needs some trivial changes - if one needs it) To use it "just" as a library compile it with "wmake libso" and have a look at the test-application that is enclosed. But I think the cooler way to use this is as an integrated part of OF because thus the linear solvers are automatically profiled Some remarks:
Bernhard Attachment 200 |
April 28, 2009, 15:30 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
OK. The forum seems to hate my attachments. I'll retry.
applicationLevelProfile.r10393.tar.gz |
April 29, 2009, 04:36 |
Rep Power: 22 |
I use the callgrind tool in valgrind and view the output with kcachegrind, this has proved a very effective way of doing detailed profiling on the optimised code without the need to recompile with profiling options.
Henry |
April 29, 2009, 13:07 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Henry!
Nevertheless I think that this extension has its applications, especially because
So I see it not as much as a programmer's tool, more as a service for the user. Bernhard |
April 29, 2009, 13:43 |
Rep Power: 22 |
Valgrind does not need any changes to the code or even recompilation. > but then a "normal" user can see where the time was lost and has quantitative information valgrind provides all the information. |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Level set vs VOF | steve | Main CFD Forum | 11 | September 16, 2008 00:22 |
MPI profiling OpenFOAM damBreak3D application | mellanoxuser | OpenFOAM Pre-Processing | 0 | April 13, 2008 23:15 |
MPI profiling OpenFOAM damBreak3D application | mellanoxuser | OpenFOAM Running, Solving & CFD | 0 | April 13, 2008 23:04 |
Relaxation factors | Vidya Raja | FLUENT | 7 | September 26, 2006 20:00 |
