June 12, 2009, 09:29 |
Extrudemesh
Niklas Wikstrom
I think there is a serious bug in extrudeMesh. Using the linearNormal model, all cells created become inside out. Extruding with negative thickness produces a valid mesh. (that ofcourse can be moved into the desired place with transformPoints, but this workaraound feels a bit awkward.) Attacheed is a test case describing this. Run the included run.sh with argument negative and positive. Cheers Niklas |
June 16, 2009, 07:21 |
Mattijs Janssens
Rep Power: 26 |
Hi Niklas,
the normal is indeed reversed. Agree it is probably not logical. I'd rather not change the behaviour in 1.5.x but will in future versions. Thanks, Mattijs |
December 6, 2009, 06:59 |
extrudeMesh - hexa cells generated?
Bence Somogyi
Dear Foamers,
I am trying to create a 2D mesh to be used in OpenFOAM with snappy. My method is the following:
Some explanatory screenshots: Result with snappy: cellSet from the middle: new mesh from cellSet: patch to extrude (why the triangles are not visualized in paraview?): result mesh with extrudeMesh: the same visualized in engrid. different colors > different cell types: pyramids visualized in engrid: tetras visualized in engrid: How can I avoid pyramids/tetras? Thanks for any help! Bence |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[mesh manipulation] ExtrudeMesh | segersson | OpenFOAM Meshing & Mesh Conversion | 5 | August 22, 2011 11:23 |
Converting mesh from gmsh | newbee | OpenFOAM Pre-Processing | 21 | January 22, 2010 06:51 |
[Salome] ExtrudeMesh for Dummies | wolle1982 | OpenFOAM Meshing & Mesh Conversion | 2 | October 28, 2008 10:35 |
[mesh manipulation] Utility to extrude into 3D mesh from a 2D mesh | hsieh | OpenFOAM Meshing & Mesh Conversion | 1 | April 9, 2006 05:37 |
