June 23, 2009, 05:50 |
OpenFOAM-1.5-extend checkMesh problem
Johan Spång
Rep Power: 17 |
In openfoam extend:
cd $FOAM_TUTORIALS/icoFoam/cavity blockMesh checkMesh ... Mesh OK. transformPoints -scale "(0.001 0.001 0.001)" checkMesh ... ***Max skewness = 116.905, 1542 highly skew faces detected which may impair the quality of the results Threshold = 4 <<Writing 1542 skew faces to set skewFaces Failed 1 mesh checks. The same procedure works fine under 1.5.x with no errors and the mesh looks ok (which it doesn't in -extend) I did recompile everything but the problem persists. Is there some tolerance settings that I have to change? -scale "(0.01 0.01 0.01)" works fine? |
June 23, 2009, 17:03 |
#2 | |
Martin Beaudoin
Rep Power: 22 |
I did the exact same sequence of commands you did with my local installation of OpenFOAM-1.5-dev (revision 1294). No tolerances tweaking. Got no error messages, and the mesh I got after calling transformPoints looks fine too. My max skewness went from 1e-08 (before transformPoints) to 2 (after transformPoints), which seems to be OK for checkMesh. " Max skewness = 2 OK. " Martin Quote:
June 24, 2009, 11:41 |
#3 | |
Johan Spång
Rep Power: 17 |
Hi Martin,
I just tried with a fresh opensuse (x64) install + latest version from svn and now I get the same output as you. Problem was on my side but it's unclear what caused it. Thank you for your attention! Regards Johan Quote:
Problem running paraFoam on OpenFOAM 1.5 | sonny | OpenFOAM | 3 | June 6, 2009 20:24 |
Eureka, OpenFoam 1.5 is running on OpenSUSE11.1 | Ahmed | Main CFD Forum | 0 | March 7, 2009 22:20 |
OpenFOAM Version 1.5 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 14, 2008 18:22 |
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 | martapajon | OpenFOAM Meshing & Mesh Conversion | 7 | January 21, 2008 12:52 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
