reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse |
July 3, 2009, 11:15 |
Adam Donaldson
Rep Power: 17 |
I am attempting to set up my dual-core computer to use MPIRUN with a case that I am running.
I decomposed the file, ran MPIRUN without a problem, and the results are distributed within the Processor0 and Processor1 directories as expected. Note that I have run MANY parallel cases on a larger network cluster in the past, so I am familiar with the general process. The problem I am encountering occurs when I attempt to use reconstructPar to reconstruct the results. The terminal output is as follows: reconstructPar /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5.x | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : reconstructPar Date : Jul 03 2009 Time : 11:02:57 Host : adona058-laptop PID : 27442 Case : /home/adona058/OpenFOAM/adona058-1.5.x/run/taylorBubbleParallel nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time fileName::stripInvalid() called for invalid fileName commandtouse For debug level (= 2) > 1 this is considered fatal Aborted I would appreciate it if someone could get back to me on why this is occuring. I can set the debug level to 0 to avoid it, but I would rather know that the program is executing correctly. Thanks, Adam |
July 3, 2009, 12:53 |
Mattijs Janssens
Rep Power: 26 |
you have an invalid named file somewhere. After stripping out the invalid characters it is 'commandtouse'.
November 19, 2009, 11:46 |
Steve Hansel
Rep Power: 16 |
November 20, 2009, 02:21 |
#4 | |
Mark Olesen
Rep Power: 40 |
Could you post which file name is getting stripped, so we can reproduce the problem. For reference, here is what src/OpenFOAM/primitives/strings/fileName/fileNameI.H states: Code:
inline bool Foam::fileName::valid(char c) { return ( !isspace(c) && c != '"' // string quote && c != '\'' // string quote ); } |
November 20, 2009, 10:32 |
Steve Hansel
Rep Power: 16 |
The filename it was working on was:
/storage/OpenFOAM_cases/lenz2_size_exp/len2_18in_tsr06_halftail The error message would report the name but leave off the _halftail part. Changing the name to /storage/OpenFOAM_cases/lenz2_size_exp/len2_18inht_tsr06 made the problem go away. I'm pretty sure I didn't have any spaces in the name, but since I changed it I can't be 100% sure. This happened with 1.5dev, so you may not want to bother with it. |
April 14, 2010, 10:35 |
Too long path name
Rep Power: 16 |
Hansel, Olesen,
I also tried to run blockMesh on a very deeply nested set of files, and it got the same error. When i copied the folder to my desktop, I could run it. |
April 14, 2010, 15:48 |
Mattijs Janssens
Rep Power: 26 |
Is this 16x on linux? We have not been able to reproduce the problem - do you have an example?
April 15, 2010, 03:26 |
deeply nested
Rep Power: 16 |
Goeiemorgen Mattijs,
I tried to run the interFoam tutorial by Hassan Hemida. The files can be downloaded from http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/. I nested everything very deeply in my file structure , namely in: Documents/OpenFOAM\ info/Chalmers/interFoam/fillBottle/lamFillBottle/ However, some other minor difficulties occurred with these files. I had to change some names of parameters like gamma to alpha and pd to p in the system files. I also had to add files like constant/turbulenceProperties and constant/g. Is this because the tutorial was written for an older version of interFoam? I am using OpenFOAM-1.6. Joris |
April 15, 2010, 04:01 |
#9 | |
Mark Olesen
Rep Power: 40 |
December 23, 2013, 10:40 |
#10 |
ahmad taheri
Rep Power: 12 |
hi
I have this problem too! I can run blockMesh but when I want too see my mesh in ParaFOAM I get this answer: fileName::stripInvalid() called for invalid fileName /home/ahmad/Desktop/tpfoch/system/fvSolution::solvers:U|k|epsilon) For debug level (= 2) > 1 this is considered fatal can you help me to solve this problem? |
December 25, 2013, 01:55 |
#11 |
Nima Samkhaniani
Rep Power: 24 |
Dear Ahmad
it return to files names usually, check that you have no extra space or unusual file name, another suggestion can be that you can copy your blockMeshDict into icoFoam/cavity , then run blockMesh and see whether it works or not
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
December 25, 2013, 02:11 |
#12 | |
ahmad taheri
Rep Power: 12 |
I copied blockMeshDict to cavity and it worked!!!! what does it mean?!?!?! |
December 25, 2013, 02:18 |
#13 |
Nima Samkhaniani
Rep Power: 24 |
it means nothing, means you should create a new test case or find where the typo is,
as i said it usually returns to bad file name
December 25, 2013, 05:37 |
#14 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Since this is a frequently asked question, I've added to the FAQ: http://openfoamwiki.net/index.php/FA..._invalid.22.3F Best regards, Bruno
June 7, 2014, 12:06 |
stripInvalid() with patch names
#15 |
Dominik Pöltl
Rep Power: 12 |
Hi foamers,
in order to get familiar with OF and especially groovyBC, I'm currently trying to get a case of 2 cyclically linked patches to work (according to this example in the wiki). Here's where the relation to this thread comes in: simpleFoam stops after having calculated u in the first timestep (after startTime) with this: Code:
word::stripInvalid() called for word p_Rect0front For debug level (= 2) > 1 this is considered fatal There are <PatchName>_front and <PatchName>_back for every patch in the inlet and outlet. In my 0/p-file, in order to use groovyBC, I defined: Code:
boundaryField{ [...] innerRect0_front { type groovyBC; variables "p_Rect0back{innerRect0_back}=sum(p*mag(Sf()))/sum(mag(Sf())); p_Rect0front=sum(p*mag(Sf()))/sum(mag(Sf())); f_relax=0.5;"; valueExpression "(p_Rect0front + f_relax*(p_Rect0back - p_Rect0front))"; value $internalField; } innerRect0_back { type zeroGradient; } Code:
p_int22 Any ideas? |
June 7, 2014, 17:42 |
#16 |
Bruno Santos
Rep Power: 128 |
Greetings Dominik,
I've Googled just now for: Code:
site:www.cfd-online.com stripInvalid groovyBC Essentially you cannot have spaces inside the variables expressions, otherwise they'll count as part of the variable names. This is essentially exemplified in the wiki page section you indicated, where not a single space is present in the variables expressions! And if you're wondering why this is still a problem since 2012, it's probably because no one has taken the time to report this on the bug tracker for swak4Foam/groovyBC . Best regards, Bruno
June 8, 2014, 05:24 |
stripInvalid() with patch names - SOLVED
#17 |
Dominik Pöltl
Rep Power: 12 |
Dear Bruno,
thanks a lot! It's sufficiently working now. I'm sorry for stirring this up when a simple "google it" is the answer. Anyway, thanks again, Dominik |
June 2, 2015, 02:29 |
Problem while converting .msh to openFoam
#18 |
Mayur Bhandari
Rep Power: 10 |
I am using command fluentMeshToFoam to convert .msh fluent mesh (from ICEM) to openfoam format.
The error is same above for debug level (= 2) 1 this is considered fatal aborted (core dumped). Please help. I'm New in this |
June 12, 2015, 18:47 |
#19 |
Bruno Santos
Rep Power: 128 |
Not enough information. Please follow the instructions given on this thread: http://www.cfd-online.com/Forums/ope...-get-help.html
December 23, 2015, 12:47 |
fileName::stripInvalid() called for invalid fileName 0
#20 |
AJAY BHANDARI
Rep Power: 10 |
HI all,
I think my post fits best here . I am getting the same error as above. First my case ran correctly without any mistake and then when i compiled it again its giving error.. fileName::stripInvalid() called for invalid fileName 0 For debug level (= 2) > 1 this is considered fatal Aborted (core dumped) Please suggest what should i do?? Any help will be appreciated.. Regards Ajay |
commandtouse, filename, reconstructpar, stripinvalid |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 05:49 |
