Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
About empty patch in parallel run
Old   July 30, 2009, 00:51
Default About empty patch in parallel run
Zheng.Zhi
Zheng.Zhi is on a distinguished road
For chtMultiRegionFoam parallel run , I have written a small modification to decomposePar that works on regions' mesh after splitMeshRegion .
After decomposition , maybe regionI's mesh all distribute in processor0 and none distribute in processor1 .
when I use symmetry plane for a 2D case , it works well , but empty patch does not work .
I found empty patch's updateCoeffs() does not allow zero mesh number:
template<class Type>
void emptyFvPatchField<Type>::updateCoeffs()
if
this->patch().patch().size()
% this->dimensionedInternalField().mesh().nCells()
FatalErrorIn("emptyFvPatchField<Type>::updateCoeff s()")
<< "This mesh contains patches of type empty but is not 1D or 2D\n"
" by virtue of the fact that the number of faces of this\n"
" empty patch is not divisible by the number of cells."
<< exit(FatalError);
When I modify updateCoeffs() , let it does nothing :
Then when regionI is a solid region, it works , but when regionI is a fluid region , still have problem :
[ff02:29082] *** An error occurred in MPI_Recv
[ff02:29082] *** on communicator MPI_COMM_WORLD
[ff02:29082] *** MPI_ERR_TRUNCATE: message truncated
[ff02:29082] *** MPI_ERRORS_ARE_FATAL (goodbye)
it occurs when solve(U equation) in UEqn.H of chtMultiRegionFoam :
fEqnResidual = solve
UEqn() == -fvc::grad(pf[i])
).initialResidual();
So I don't know why empty patch can't work when regionI have Zero mesh number in processor1 , but symmetry plane can work well .
Can anybody help me with this problem? Thanks.
Zheng.Zhi is offline   Reply With Quote
Old   July 30, 2009, 07:55
Mattijs Janssens
mattijs is on a distinguished road
I've pushed a fix for the division by zero (cells) to 1.6.x.
2) if you are running chtMultiRegionFoam, the 1.6 version allows independent decomposition of all regions so you're highly unlikely to get zero cells. Look at the Allrun script in the tutorial.
mattijs is offline   Reply With Quote
Old   August 2, 2009, 22:01
Zheng.Zhi
HiMr.Mattijs :
I've run the multiRegionHeater tutorial of OpenFoam version 1.6 , yes the chtMultiRegionFoam can run in parallel well . That's great , Thank you very much Mattijs .
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Cyclic patch in parallel calculations didomenico OpenFOAM Running, Solving & CFD 4 March 7, 2007 05:46
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 06:33
Minimum number of nodes to run CFX in parallel Rui CFX 3 April 11, 2005 20:46
How to run parallel in ICEM_CFD? Kiddo Main CFD Forum 2 January 24, 2005 08:53
