Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Zero size field
Old   April 14, 2010, 04:06
Default Zero size field
taranov is on a distinguished road
Hello, everybody!
We use OF 1.6.x from the git repository. And we found the following strange feature or even a bug:
A nonuniform field F of type T, for example of type T = vector, is represented
in a dictionary as
F nonuniform List<vector>
n
(fx1 fy1 fz1)
(fx2 fy2 fz2)
(fxn fyn fzn)
where n is the size of the field. But if the size is zero, n=0, then the field
F is written to the dictionary as
F nonuniform 0();
so the information about the type of the field is lost. If this field has been
decomposed and its size in the processor0 is zero
then this field is assumed to be the field of scalar during reconstruction,
which leads to problems if the actual type of the field is not scalar.
Please comment on this behavior.
Thanks in advance,
Andrey Taranov
taranov is offline   Reply With Quote
Old   April 15, 2010, 03:10
henry is on a distinguished road
Could you provide a small case which reproduces the problem?
H
henry is offline   Reply With Quote
Old   April 20, 2010, 04:51
Dear Henry,
we have found that this problem is connected with the reconstructPar application. We have a shared library of our extensions to OpenFOAM. This library contains, among other things, a new type of boundary condition.
The new boundary condition class is derived from one of the standard OpenFOAM classes and has two members of types vectorField and tensorField.
We decomposed our case in such a way that the whole inlet went to
the last processor, so the sizes of the decomposed parts of these fields in
all other processors, including the master process, are zero. These fields in
all other processors were written to the dictionary file as
vField nonuniform 0();
tField nonuniform 0();
When we reconstructed our case, these fields were reconstructed incorrectly,
i.e. they were reconstructed as fields of scalar with very tiny (but nonzero)
values. When we decomposed our case in such a way that the whole inlet went to
the master process, reconstructPar worked correctly.
There are two solutions to this problem. The first one is to manually insert the definitions of the type into all other processors
vField nonuniform List<vector> 0();
tField nonuniform List<tensor> 0();
The other solution is to relink reconstructPar with our shared library. We
think that it would be much better to write the information about the type of
the field even when size of this field is zero.
Best regards,
Andrey Taranov
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
