Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
kOmegaSSTSAS implementation in OF 2.1
Old   May 13, 2012, 11:48
Default kOmegaSSTSAS implementation in OF 2.1
Ben Colcord
RealSoutherner is on a distinguished road
I think there are errors in the implementation of the kOmegaSSTSAS model in OF 2.1, but I'm not certain.
Firstly, the production term G differs from the kOmegaSST model and the basic kOmega model, where I believe they should be consistent. OF 1.6 has a consistent formulation in all 3.
In kOmegaSSTSAS(OF2.1):
S2 = 2*magSqr(symm(fvc::grad(U)));
G = nuSgs*0.5*S2;
nuSgs = a1*k/max(a1*omega, F2()*sqrt(S2));
In kOmegaSST(OF2.1):
G = nut*S2;
nut = a1*k/max(a1*omega, F2()*sqrt(S2));
So, G is half the magnitude in the kOmegaSSTSAS model. I can't find anywhere in the literature where this is true, but maybe someone knows. I have tested both formulations on a turbulent channel flow and actually see a slightly better result with the new "wrong" formulation, which makes me question the wrongness.
Secondly, the related term in the omega equation is given as gamma(F1)*0.5*S2. This is how it's shown in Menter et al (Ten Years of Industrial Experience with the SST Turbulence Model, 2003) but in Menter et al (The SST Turbulence Model with Improved Wall Treatment..., 2003) it is given (using OF variables) as gamma(F1)*G/nut. Furthermore, at http://turbmodels.larc.nasa.gov/sst.html, the formulation that OF uses is said to be an error in the original paper. This also affects the kOmegaSST model in OF.
Hopefully someone can confirm these errors or knows where in the literature these modifications have been made. Thanks.
RealSoutherner is offline   Reply With Quote
Old   August 17, 2012, 01:31
Tarak
Tarak is on a distinguished road
Hii,
This was a bug in OF and has been rectified through mantis bugtracker with ID 0000575 (you can see the edited version in the git repository). This reduced production term was leading to a spurious reduction of turbulent viscosity.
Tarak is offline   Reply With Quote
No reactions in reactingFoam 2.1 OMN OpenFOAM Running, Solving & CFD 16 April 7, 2015 12:14
a little confused with the implementation of compressibleInterFoam su_junwei OpenFOAM Running, Solving & CFD 2 May 7, 2014 17:33
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch thomek OpenFOAM Programming & Development 0 October 18, 2010 05:10
Request for help so as to debug MAC implementation HectorRedal Main CFD Forum 0 September 13, 2010 16:52
Please explain the implementation of species transport Eqn in reactingFoam kallipygian OpenFOAM Running, Solving & CFD 0 October 13, 2008 07:29
