Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
TwoPhaseEulerFoam bed tutorial case crashes in 1.6. Stable in 1.5
Old   December 4, 2009, 02:43
Default TwoPhaseEulerFoam bed tutorial case crashes in 1.6. Stable in 1.5
Rasmus Hemph
hemph is on a distinguished road
The tutorial "bed" for twoPhaseEulerFoam crashes under 1.6. Nu such problem with the 1.5 version.
The problem seems related to turbulence, but I have not pinpointed it further.
I am seeing the same behavior with my own work. TwoPhaseEulerFoam-cases which ran under 1.5 are more unstable and crashes frequently in 1.6.
I started a thread on the issue at http://www.cfd-online.com/Forums/ope...tml#post238702.
Best regards,
Rasmus H
hemph is offline   Reply With Quote
Old   December 5, 2009, 17:34
henry is on a distinguished road
I changed the default value of "E" used in the wall-functions to a more standard value and now this case runs to completion. This change is now in our OpenFOAM-1.6.x git repository.
H
henry is offline   Reply With Quote
Old   February 17, 2010, 08:10
Nicoleta Scurtu
nscurtu is on a distinguished road
H
Based on the tutorial "bed2" for twoPhaseEulerFoam I tried to simulate the fluidization process. My trouble is that after few simulation steps in the freeboard region the solid velocity exists, shows oposit to the inflow velocity direction and is extremly high in magnitude compared to the inflow velocity. The field "alpha = 0" in the freeboard means that no solid-phase exists there, so why a solid-phase velocity exists however?
The same problem I simulated with Fluent and MFIX, which gives similar results, but those of twoPhaseEulerFoam are total different and unphysical concerning the solid-phase velocity field. Has anybody an idea what might be the reason?
regards,
N.S.
nscurtu is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
ChtMuliRegionFoam-Case (OF 1.6 Tutorial-case -> OF 1.5) suitup OpenFOAM 15 November 11, 2009 12:43
Forces in 1.5 with an Ahmed VWT case terrybarnaby OpenFOAM Running, Solving & CFD 3 June 9, 2009 08:21
FoamX refuses to open an interFoam tutorial case vrecha OpenFOAM Pre-Processing 5 March 12, 2008 12:36
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
