Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OpenFOAM-1.5-dev svn revision 1438: ParaFoam does not compile
Old   October 14, 2009, 12:11
Exclamation OpenFOAM-1.5-dev svn revision 1438: ParaFoam does not compile
4xF
Frank Albina
4xF is on a distinguished road
Send a message via Skype™ to 4xF
Hi all!
This is a call to the 1.5-dev maintainers.
Another show stopper on this svn revision #1438 of OpenFOAM-1.5-dev. Apparently the buildParaviewFunctions and the buildParaView3.3-cvs script are both broken. The buildParaView-3.3-cvs calls functions which are no longer declared in buildParaviewFunctions, and even replacing the buildParaView functions by the ones of 1.5.x does not fix the problem. Replacing the buildParaView3.3-cvs by the one of 1.5.x fixes it.
I guess that this does not show up when you have compiled ParaFoam with a previous svn revision and are updating on a regular basis.
I guess that something went wrong during a svn commit, but it is a wild guess.
Can anyone with permissions to the SVN repository fix this?
Thanx.
4xF is offline   Reply With Quote
Old   October 16, 2009, 05:41
Hrvoje Jasak
Me again. Sorry, Thy Will Be Done.
As you say, it happens whey you don't regularly rebuild the system.
I would be grateful for any other fixes you find. BTW, pleas tell me your name if you wish to have the fixes signed by you in SVN (simply to give you credit for the work).
Hrv
Hrvoje Jasak
1.5-dev, build scripts, parafoam, rev.1438
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 05:35
Problem running paraFoam on OpenFOAM 1.5 sonny OpenFOAM 3 June 6, 2009 20:24
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 06:28
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
