Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
fvc::grad(U) failing in parallel
Old   May 18, 2021, 05:20
Default fvc::grad(U) failing in parallel
Wael Itani
waelitani is on a distinguished road
I have a custom boundary condition which computes the gradient of the velocity field to compute its value. It works fine in serial run. However, it fails in parallel.
uName = this->internalField().name();
const volVectorField& U = db().lookupObject<volVectorField>(uName);
volTensorField gradU = fvc::grad(U);
When the last line is commented it runs fine. Otherwise, it gives the below error. U.size() shows the correct number of cells for the processor.
[0] From const T& Foam::UPtrList<T>:perator[](Foam::label) const [with T = Foam::fvPatchField<Foam::Vector<double> >; Foam::label = int]
[0] in file /home/user/openfoam/BuildEnv/debian-build/focal-2012.latest/scratch/src/OpenFOAM/lnInclude/UPtrListI.H at line 218.
[0]
FOAM parallel run aborting
[0]
[0] #0 Foam::error:rintStack(Foam::Ostream&)[1]
[1]
[1] --> FOAM FATAL ERROR: (openfoam-2012)
[1] Cannot dereference nullptr at index 0 in range [0,12)
[1]
[1]
[1] From const T& Foam::UPtrList<T>:perator[](Foam::label) const [with T = Foam::fvPatchField<Foam::Vector<double> >; Foam::label = int]
[1] in file /home/user/openfoam/BuildEnv/debian-build/focal-2012.latest/scratch/src/OpenFOAM/lnInclude/UPtrListI.H at line 218.
[1]
[1]
[1] #0 Foam::error:rintStack(Foam::Ostream&)[LAPTOP-U0DBOLPO:28182] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[LAPTOP-U0DBOLPO:28182] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
./runThis.sh: line 5: recomposePar: command not found
waelitani is offline   Reply With Quote
boundary, bug, grad, programming
[ANSYS Meshing] Parallel meshing utilisation failing crc1622 ANSYS Meshing & Geometry 0 February 14, 2019 02:42
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 13:44
