Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
settlingFoam fails with timeVarying conditions on U
Old   April 20, 2010, 21:32
Default settlingFoam fails with timeVarying conditions on U
Alberto Passalacqua
Bug
settlingFoam fails when a timeVarying boundary condition is used for the U field, since Vdj inherits the boundaryField from U, leading the code to a segmentation fault when
Vdj.correctBoundaryConditions();
is executed.
Proposed solution
I'm not sure why Vdj inherits the BC's from V, since it is computed explicitly. However a workaround could be to replace the declaration of Vdj in createFields.H with (I left the commented line).
volVectorField Vdj
        IOobject
            "Vdj",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh,
        dimensionedVector("0.0", U.dimensions(), vector::zero)
        //,U.boundaryField().types()
Best,
Alberto Passalacqua
Old   April 21, 2010, 14:16
Fran
lfbarcelo is on a distinguished road
The bug also exists for alpha BC, since Alpha inherits the boundaryField from alpha.
I tried a similar fix for this BC.
volScalarField Alpha
        IOobject
            "Alpha",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
        alpha*rhod/rho
        //,alpha.boundaryField().types()
Where I commented the comma and the last line.
But I get the next error message when trying to run the case:
Starting time loop
Time = 0.1
Courant Number mean: 0.00597056 max: 0.0488136
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.67271e-10, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.12603e-10, No Iterations 3
--> FOAM FATAL ERROR:
gradientInternalCoeffs cannot be called for a calculatedFvPatchField
on patch lowerWall of field Alpha in file "/home/pablo/OpenFOAM/pablo-1.6.x/run/V_1/0/Alpha"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<Type>::gradientInternalCoef fs() const
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187.
FOAM exiting
I've tried creating the Alpha BC in the 0 folder of the case, and reading that boundaryField instead of inheriting it from alpha:
        IOobject
            "Alpha",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
       mesh
        // alpha*rhod/rho
I changed NO_READ for MUST_READ, and commented the line where it calculates Alpha for the first step. I also added the word mesh.
It seems to work fine, but I had to manually calculate and create the Alpha bondaryField File in the 0 folder, and apply the timeVaryingUniformFixedValue to this BC instead of applying it to alpha.
P.S.: Note the difference between alpha and Alpha. Alpha= alpha*rhod/rho
lfbarcelo is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
InterDyMFoam dynamic messing in parallel fails under nonquiescent conditions adona058 OpenFOAM Running, Solving & CFD 5 August 19, 2010 11:47
InterDyMFoam dynamic meshing in parallel fails under nonquiescent conditions adona058 OpenFOAM Bugs 7 November 18, 2008 14:58
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 06:25
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
