Sign inconsistency in the compressible Launder-Sharma k-epsilon model |
March 15, 2012, 05:15 |
Vesselin Krastev
Rep Power: 20 |
Hi all,
checking the epsilon transport equation in the Launder-Sharma low-Re model I've found a clear inconsistency in the C3 constant sign (at least it is there in the OF-2.1.0 release, I don't know if it has been already fixed in 2.1.x). The following is the (correct) compressibility production term in the standard k-epsilon model implementation: - fvm::SuSp(((2.0/3.0)*C1_ + C3_)*rho_*divU, epsilon_) As you can see, the term multiplied by C1 enters with a negative sign, while the term multiplied by C3 actually becomes positive, as in OF C3 is equal to -0.33 while the correct constant value in the RHS of the epsilon equation should be +0.33. This is the same (incorrect) term in the Launder-Sharma model: + fvm::SuSp((C3_ - 2.0/3.0*C1_)*rho_*divU, epsilon_) The C1 term is again negative, but so it is the C3 one as in OF +C3=-0.33. So, I don't know what is the real influence of such an error, but to me this is clearly a bug (I will report it to the bug tracker in a while). Greetings to all V. (Reported) http://www.openfoam.org/mantisbt/view.php?id=462 Last edited by vkrastev; March 15, 2012 at 05:23. Reason: Bug tracker reference added |
Low Reynolds K Epsilon Launder Sharma Model Functions Doubt... | Ruonin | Main CFD Forum | 17 | February 17, 2014 09:52 |
Herschel-Bulkley non-Newtonian viscosity model has term with sign error | pbryant | OpenFOAM Bugs | 5 | June 18, 2013 23:53 |
derivation of epsilon equation of k-epsilon model | Ricardo Rezende | Main CFD Forum | 5 | May 1, 2007 05:38 |
Wall Boundary Condition in k - epsilon model | abhijeet vaidya | Main CFD Forum | 0 | July 14, 2002 03:18 |
Launder & Sharma model in combusion case | Richard Carroni | Main CFD Forum | 1 | November 17, 1998 18:59 |
