wmake turns evil ???!!!
wmake has suddenly decided to randomly delete my source files when compiling. It happens during the wmakeLnInclude. Good thing I have backups! Here's the output:
dave@Bruce:~/OpenFOAM/dave-1.5-dev/src/PhD$ wmake libso wmakeLnInclude: linking include files to /home/dave/OpenFOAM/dave-1.5-dev/src/PhD/lnInclude ln: creating symbolic link `./multiSolverInit.H': File exists ln: creating symbolic link `./setSolverDomain.H': File exists ln: creating symbolic link `./endMultiSolver.H': File exists ln: creating symbolic link `./multiSolverSetControls.C': File exists ln: creating symbolic link `./multiSolver.H': File exists ln: creating symbolic link `./createMultiSolver.H': File exists ln: creating symbolic link `./multiSolverSetInitialSolverDomain.C': File exists ln: creating symbolic link `./multiSolverTimeFunctions.C': File exists ln: creating symbolic link `./multiSolverI.H': File exists ln: creating symbolic link `./multiSolver.C': File exists ln: creating symbolic link `./multiSolverSetNextSolverDomain.C': File exists Making dependency list for source file admScalar/admScalar.C Making dependency list for source file buoyantPressure/buoyantPressureFvPatchScalarField.C Making dependency list for source file dummyControlDict/dummyControlDict.C make: *** No rule to make target `multiSolver/multiSolver.dep', needed by `Make/linux64GccDPOpt/dependencies'. Stop. make: *** Waiting for unfinished jobs.... dave@Bruce:~/OpenFOAM/dave-1.5-dev/src/PhD$ Every file that failed with ln (file exists) is deleted... mercilessly. (No name.H~ to save the day) The files getting deleted I haven't touched for about a week, and have survived a wmake libso since then. All I did was add another couple of sources (none of the deleted files) to the library, and execute wmake libso. I frequently am adding sources to the library, the only difference I can think of is these ones are 2 directories deep, as opposed to one. Any ideas? |
Greetings David,
Uhm, are you by any chance putting the real files directly in lnInclude? Because lnInclude is a temporary folder, mainly for symbolic links to the headers, and meant for making it easier for wmake to build the desired binary! Best regards, Bruno |
Good idea... but no. The problem even occurs after deleting lnInclude, and the .dep, all the Make/linux directories.
Hmm... that is strange... can you post the contents of the file Make/files? There should be a logical reason for wmake to go postal :rolleyes:
edit: it would also be good to know what the file Make/options has inside it! |
buoyantPressure/buoyantPressureFvPatchScalarField.C admScalar/admScalar.C dummyControlDict/dummyControlDict.C multiSolver/multiSolver.C multiTimeInstant/multiTimeInstant.C timeCluster/timeCluster.C timeCluster/timeClusterList.C // equation/equationMaster/equationMaster.C // equation/equation/equation.C // equation/equationOperation/equationOperation.C // admScalar/admScalarList.C LIB = $(FOAM_USER_LIBBIN)/libPhD And here is my Make/options: EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -Ituple2Lists LIB_LIBS = \ -lfiniteVolume |
Problem found
It was a file name collision.
PhD |-timeCluster |-Make |-multiSolver |-multiSolver_beforeChanges |-multiSolver_bak '-tuple2lists I had copied the multiSolver directory to another name to archive some changes I was making. When wmakeLnInclude runs, it deletes all the duplicate source files in all directories, leaving only one copy... in my case, it left me the "multiSolver_beforeChanges" files. Once I got rid of the archive directories, wmake started behaving again. I'm thinking that's a pretty poor fail mode for a file name collision! |
Hi Wyldcat,
During the compilation I have the following message: wmakeLnInclude: linking include files to ./lnInclude ln: failed to create symbolic link `./Lee.H': File exists ln: failed to create symbolic link `./Lee.C': File exists Is it wrong or it does not matter? |
This "lnInclude" folder is meant to be used for symbolic links only, therefore if that message is being given, then you better double-check if those files are meant to be there on purpose or if they were accidentally moved into that folder. Is this message showing up with any particular community contribution (namely, source code made available online) or is it code that you're creating yourself? I ask this because if it's from something shared online, then we need to review the code with the respective authors, in order to fix this. |
Hi wyldcat,
This is my source code. This situation appeared when: 1) firstly I compiled Lee.C and Lee.H files using wmake 2) then I deleted Lee files and compiled other anotherModel.C and andotherModel.H files 3) finally I came back to Lee model and deleted anotherModel files after step 3 the message I mentioned in my post appeared, namely wmakeLnInclude: linking include files to ./lnInclude ln: failed to create symbolic link `./Lee.H': File exists ln: failed to create symbolic link `./Lee.C': File exists So I did not copy Lee files into lnInclude directory. How to remove this massage? |
