Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
[blockMesh] arbitrary behaviour at creation of arc edges
Old   January 29, 2011, 06:15
Default [blockMesh] arbitrary behaviour at creation of arc edges
kpm
kpm
kpm is on a distinguished road
As I received an "APPLICATION ERROR #2800" upon trying to set my password after following the link for the mantis registration, I report my issue here:
I believe there is a bug in blockMesh.
ArcEdges sometimes evolve around the wrong portion of the circle.
For example, if I define a 90 degree arc, the edge will try to exist
along the remaing 270 degrees of the circle, even if the middle
point isn't in this portion of the circle.
Swapping start and end points didn't help.
The issue seems to be affected by the arc edge's orientation to the coordinate system.
Refer to the attached picture. The radial tubes have arc edges in tangential planes
to create a circular cross-section.
The only tube that comes out correctly is the one where the tangential planes
of the arcs are within the y-z-plane.
If I create blocks around the radial tubes, the issue disappears,
and the arc edges turn out correctly.
blockMesh should either create arcs correctly, preferably such that the middle point
is actually in the middle of the arc, or provide additional dictionary options to
control arc creation.
blockMeshDict attached
kpm is offline   Reply With Quote
Old   February 7, 2011, 08:29
kpm
kpm
Sorry folks, that bug was not in blockMesh, but somewhere between keyboard and chair.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
weird error during blockMesh SePe OpenFOAM 1 October 25, 2010 10:31
Axisymmetric Grid N. A. OpenFOAM 5 July 2, 2010 10:39
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
