Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
decomposePar memory corruption
Old   July 1, 2011, 04:05
Default [solved] decomposePar memory corruption
Lorenzo A. Ricciardi
lichmaster is on a distinguished road
Hi Foamers,
this is my first post, and I'm also rather new to OpenFoam as well.
I've implemented an actuator disk solver as in
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/erikSvenning/erikSvenningReport.pdf
I had to change some minor things, for that tutorial was written for OF 1.5 dev and I've OF 1.71 and OF 2... however, it compiled fine and also seems to work fine on single processor (still have to test the results, though)
The problem is: if I try to run decomposePar, i get a memory corruption message, which never occurred before... Any ideas about what to check?
checkMesh gives no errors, and it's a simple "box" geometry with 512k cells created with blockMesh
Since it works correctly with other solvers, is there any chance that the error somehow comes from the new solver?
Thanks
lichmaster is offline   Reply With Quote
Old   July 4, 2011, 05:30
I've managed to solve this problem...
I didn't correctly set the I.C of VolumeForce: the object entry was still "U" instead of "VolumeForce".
However, I find it very strange that no "canonical" error messages are given for this kind of mistakes, and also that single processor simulations have no problems at all...
decomposepar, memory corruption
Fluent Parallel Memory Usage David Christopher FLUENT 1 March 3, 2011 02:20
How to optimize the memory usage when using FEM vasilis Main CFD Forum 11 August 24, 2009 23:57
Memory error? Young CFX 3 September 30, 2008 11:33
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
Run-Time memory conifguration Error Graeme CFX 1 February 20, 2006 23:04
