Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Error when using solidEquilibriumDisplacementFoam
Old   August 7, 2011, 07:26
Default Error when using solidEquilibriumDisplacementFoam
Guilherme Sempionato
sempionato is on a distinguished road
Hi people,
I am using solidEquilibriumDisplacementFoam to generate a solution of a static linear simulation of a vehicle cabin with a pressure imposed but the code have diverged with few iterations. Does anybody knows this error?
The mesh was generated with netgen with +-50000 elements and the error seems not be influenced by DeltaT.
Thanks.
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
Floating point exception.
sempionato is offline   Reply With Quote
Old   August 8, 2011, 11:19
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Without knowing more about your case,
your case probably diverges because of either bad boundary conditions or a bad mesh or both.
You need to post more information about your case for more help, such as what boundary conditions you are using, and also whether "checkMesh" says your mesh is OK.
Also you should probably post this thread in the main openfoam forum, and not in the bug section.
Philip
bigphil is offline   Reply With Quote
