Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
LiencubiclowRemodel
Old   August 23, 2007, 23:16
Default Hi, there: I think I found
Ning Yang
nzy102 is on a distinguished road
Hi, there:
I think I found a bug in liencubiclowRe model c file. The definition of nonlinearstress is as follows:
nonlinearStress
"nonlinearStress",
symm
// quadratic terms
pow(k_, 3.0)/sqr(epsilon_)*
Ctau1/fEta*
(gradU & gradU)
+ (gradU & gradU)().T()
+ Ctau2/fEta*(gradU & gradU.T())
+ Ctau3/fEta*(gradU.T() & gradU)
// cubic term C4
- 20.0*pow(k_, 4.0)/pow(epsilon_, 3.0)*
pow(Cmu, 3.0)*
((gradU & gradU) & gradU.T())
+ ((gradU & gradU.T()) & gradU.T())
- ((gradU.T() & gradU) & gradU)
- ((gradU.T() & gradU.T()) & gradU)
// cubic term C5, explicit part
+ min
C5viscosity,
dimensionedScalar("0", C5viscosity.dimensions(), 0.0)
)*gradU
here is the definitio of the Reynolds Stress:
tmp<volsymmtensorfield> LienCubicKELowRe::R() const
return tmp<volsymmtensorfield>
new volSymmTensorField
IOobject
"R",
runTime_.timeName(),
mesh_,
IOobject::NO_READ,
IOobject::NO_WRITE
((2.0/3.0)*I)*k_ - nut_*twoSymm(gradU) + nonlinearStress,
k_.boundaryField().types()
I think the correct definition should be:
((2.0/3.0)*I)*k_ - nut_*twoSymm(gradU) + nonlinearStress*fmu
where fmu is the damping function.
Reference:
Lien, F.S., Chen, W.L., Leschziner, M.A., 1996. Low-Reynolds-number eddy-viscosity modeling based on non-linear stress-strain/vorticity relations. Engineering Turbulence Modelling and Experiments 3 (Edited by Rodi, W. and Bergeles, G.), 91-100. Elsevier Science Publishers.
Etemad, S., et al., 2006. Turbulent flow and heat transfer in a square-sectioned U bend. Progress in compuational fluid dynamics 6, 89-100.
nzy102 is offline   Reply With Quote
Old   August 24, 2007, 03:21
Default Do you think the nonlinearStre
henry is on a distinguished road
Do you think the nonlinearStress should also be multiplied by fMu in the other terms i.e. in LienCubicKELowRe::divR and G? If so it could simply be multiplied by fMu when it is calculated at the bottom of LienCubicKELowRe::correct().
henry is offline   Reply With Quote
Old   August 28, 2007, 20:10
Default Hi Henry: Thank you for you
Ning Yang
Hi Henry:
Thank you for your help. There are several places I have to make changes. I modified nonlinearstress, fmu, nut, epsEqn, and lienleschzinerlowReSetWallDissipatoin.H file.
Then I compiled the new lienleschzinerLowRe with the following make/files:
turbulenceModel/turbulenceModel.C
turbulenceModel/newTurbulenceModel.C
laminar/laminar.C
LienCubicKELowRe/LienCubicKELowRe.C
wallFunctions/nutWallFunctions/nutWallFunction/nutWallFunctionFvPatchScalarField .C
wallFunctions/nutWallFunctions/nutStandardWallFunction/nutStandardWallFunctionFv PatchScalarField.C
wallFunctions/nutWallFunctions/nutStandardRoughWallFunction/nutStandardRoughWall FunctionFvPatchScalarField.C
LIB = $(FOAM_LIBBIN)/libincompressibleTurbulenceModels
It turns out that I got errors as follows:
: undefined reference to `Foam::fvPatchField<double>::dictionaryConstructor TablePtr_'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text+0x1): In function `__tcf_4':
: undefined reference to `Foam::fvPatchField<double>::destroydictionaryCons tructorTables()'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text+0x11): In function `__tcf_3':
: undefined reference to `Foam::fvPatchField<double>::destroypatchMapperCon structorTables()'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text+0x21): In function `__tcf_2':
: undefined reference to `Foam::fvPatchField<double>::destroypatchConstruct orTables()'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text._ZNK4Foa m22fixedV alueFvPatchFieldIdE4typeEv[Foam::fixedValueFvPatchField<double>::type() const]+0x3): In function `Foam::fixedValueFvPatchField<double>::type() const':
: undefined reference to `Foam::fixedValueFvPatchField<double>::typeName'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text._ZNK4Foa m22fixedV alueFvPatchFieldIdE22gradientBoundaryCoeffsEv[Foam::fixedValueFvPatchField<doubl e>::gradientBoundaryCoeffs() const]+0x19): In function `Foam::fixedValueFvPatchField<double>::gradientBou ndaryCoeffs() const':
: undefined reference to `Foam::fvPatch::deltaCoeffs() const'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text._ZNK4Foa m22fixedV alueFvPatchFieldIdE22gradientInternalCoeffsEv[Foam::fixedValueFvPatchField<doubl e>::gradientInternalCoeffs() const]+0xd): In function `Foam::fixedValueFvPatchField<double>::gradientInt ernalCoeffs() const':
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text._ZNK4Foa m14object Registry12lookupObjectINS_14GeometricFieldIdNS_12f vPatchFieldENS_7volMeshEEEEERK T_RKNS_4wordE[Foam::GeometricField<double,> const& Foam::objectRegistry::lookupObject<foam::geometric field<double,> >(Foam::word const&) const]+0x125): In function `Foam::GeometricField<double,> const& Foam::objectRegistry::lookupObject<foam::geometric field<double,> >(Foam::word const&) const':
: undefined reference to `Foam::GeometricField<double,>::typeName'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text._ZNK4Foa m14object Registry12lookupObjectINS_14GeometricFieldIdNS_12f vPatchFieldENS_7volMeshEEEEERK T_RKNS_4wordE[Foam::GeometricField<double,> const& Foam::objectRegistry::lookupObject<foam::geometric field<double,> >(Foam::word const&) const]+0x290): In function `Foam::GeometricField<double,> const& Foam::objectRegistry::lookupObject<foam::geometric field<double,> >(Foam::word const&) const':
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text._ZNK4Foa m14object Registry12lookupObjectINS_14GeometricFieldINS_6Vec torIdEENS_12fvPatchFieldENS_7v olMeshEEEEERKT_RKNS_4wordE[Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<foam::geometric field<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const]+0x125): In function `Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<foam::geometric field<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const':
: undefined reference to `Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
Make/linux64GccDPOpt/nutWallFunctionFvPatchScalarField.o(.text._ZNK4Foa m14object Registry12lookupObjectINS_14GeometricFieldINS_6Vec torIdEENS_12fvPatchFieldENS_7v olMeshEEEEERKT_RKNS_4wordE[Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<foam::geometric field<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const]+0x290): In function `Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<foam::geometric field<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const':
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x6bc): In function `Foam::turbulenceModels::nutStandardWallFunctionFv PatchScalarField::evaluate()':
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x18e9): In function `__static_initialization_and_destruction_0(int, int)':
: undefined reference to `Foam::fvPatchField<double>::constructpatchConstru ctorTables()'
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x1904): In function `__static_initialization_and_destruction_0(int, int)':
: undefined reference to `Foam::fvPatchField<double>::patchConstructorTable Ptr_'
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x1922): In function `__static_initialization_and_destruction_0(int, int)':
: undefined reference to `Foam::fvPatchField<double>::constructpatchMapperC onstructorTables()'
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x193d): In function `__static_initialization_and_destruction_0(int, int)':
: undefined reference to `Foam::fvPatchField<double>::patchMapperConstructo rTablePtr_'
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x195b): In function `__static_initialization_and_destruction_0(int, int)':
: undefined reference to `Foam::fvPatchField<double>::constructdictionaryCo nstructorTables()'
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x1973): In function `__static_initialization_and_destruction_0(int, int)':
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x1): In function `__tcf_4':
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x11): In function `__tcf_3':
Make/linux64GccDPOpt/nutStandardWallFunctionFvPatchScalarField.o(.text+ 0x21): In function `__tcf_2':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x7c 9): In function `__static_initialization_and_destruction_0(int, int)':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x7e 4): In function `__static_initialization_and_destruction_0(int, int)':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x80 2): In function `__static_initialization_and_destruction_0(int, int)':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x81 d): In function `__static_initialization_and_destruction_0(int, int)':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x83 b): In function `__static_initialization_and_destruction_0(int, int)':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x85 3): In function `__static_initialization_and_destruction_0(int, int)':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x14 3c): In function `Foam::turbulenceModels::nutStandardRoughWallFunct ionFvPatchScalarField::evaluat e()':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x1) : In function `__tcf_4':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x11 ): In function `__tcf_3':
Make/linux64GccDPOpt/nutStandardRoughWallFunctionFvPatchScalarField.o(. text+0x21 ): In function `__tcf_2':
collect2: ld returned 1 exit status
make: *** [OpenFOAM.out] Error 1
The weird thing is I got the same error even when I compiled other available turbulence models in the foam such as KE, LRR, etc.
Do you have any suggestions?
Ning
Old   August 28, 2007, 20:49
Default I had a similar post several d
Quinn Tian
qtian is on a distinguished road
I had a similar post several days ago with no answer yet. I also tried to recompile the turbulence models again without making any change and received similar error message.
Ning, if you happen to solve this problem, could you please share this information with me? thanks a lot.
Quinn
qtian is offline   Reply With Quote
Old   August 29, 2007, 02:52
Default Which version of OpenFOAM are
Which version of OpenFOAM are you using?
Which compiler are you using?
Have you compiled everything from sources?
Old   August 29, 2007, 03:48
Default I am using openfoam 1.4.1. wit
Ning Yang
I am using openfoam 1.4.1. with Intel c++ compiler. And in the "files" file of "make" folder, I have:
laminar/laminar.C
everything is compiled under /src/turbulenceModels/incompressible using wmake. I guess my question is if i have to recompile all the other turbulent models. Is there anything else I have to do?
Thanks.
Ning
Ning
Old   August 29, 2007, 04:38
Default Did you compile the library us
Did you compile the library using wmake libso?
Old   August 29, 2007, 09:25
Default Henry, Thank you so much fo
Quinn Tian
Henry,
Thank you so much for your help. My problem is solved. I did not realize that there is some difference between compiling application and dynamic lib.
Old   August 30, 2007, 10:02
Default Henry: It works fine now. T
Ning Yang
Henry:
It works fine now. Thanks. One more thing: do you know the source paper of liencubiclowRe model in the foam?
Ning
Old   August 30, 2007, 10:19
Default It was implemented as part of/
It was implemented as part of/following a turbulence model assessment project involving Imperial College. I have an unpublished report containing the details of this and the other non-linear models somewhere which I can dig-up if it is important. I have not checked or even used the model in OpenFOAM and there may be errors in it or it may be that it is a correct implementation of the form published at the time and you are working from more recent documents.
Do you now have a form consistent with the publications you are working from? Can you send details of the changes you have made or better still post the new version?
Old   August 30, 2007, 11:09
Default I implemented two versions: hi
  #11
Hrvoje Jasak
I implemented two versions: high-Re with wall functions and low-Re. Here are the references I've used:
@Article{Lien:CUBICKE,
author = {Lien, F.S. and Leschziner, M.A.},
title = {Modelling 2D separation from a high lift airfoil
with a non-linear eddy viscosity model and second
moment closure},
journal = {Aeronautical Journal},
year = 1995,
pages = {125-144}
@InProceedings{Lien:LOWRECUBICKE,
author = {Lien, F.S. and Chen, W.L. and Leschziner, M.A.},
title = {Low-Reynolds-number eddy-viscosity modelling based
on non-linear stress-strain-vorticity relations},
booktitle = {Proc. 3rd Symp. on Engineering Turbulence Modelling
and Measurements},
year = 1996,
address = {Crete, Greece},
month = {May}
Enjoy,
Hrv
Hrvoje Jasak
Old   August 30, 2007, 15:19
Default The liencubiclowRe code in the
  #12
Ning Yang
The liencubiclowRe code in the foam is different from lien's paper of Low-Reynolds-number eddy-viscosity modelling based on non-linear stress-strain-vorticity relations. Specifically, the differences are nonlinearstresses, fmu, the transport equation for epsilon, and wall dissipation. I changes the code and am testing the code now. If it works fine, I will post on the forum. One more question though: the definition of nut in the foam liencubiclowRe code is:
nut_ =
Cmu*fMu*sqr(k_)/epsilon_;
C5 term, implicit
+ max
C5viscosity,
I don't see this expression in lien's papers at all. I think the correct form is
nut_ = Cmu*fMu*sqr(k_)/epsilon_;
Can you explain what is the second term on the right for? Thanks.
Ning
Old   September 6, 2007, 06:42
Default Henry, I am interested in t
  #13
Martin Karlsson
martin is on a distinguished road
Henry,
I am interested in the report regarding non-linear turbulence models in foam. Is it possible to get one copy?
Thanks in advance,
Martin
martin is offline   Reply With Quote
Old   September 6, 2007, 06:55
Default The project was called the Rey
  #14
Hrvoje Jasak
The project was called the Reynolds Solver project, sponsored by Audi, BMW, Ford,. Mercedes-Benz, Opel, Porsche and Renault and the European Union. I did a part of my PhD work on this: error estimation, automatic adaptive error-driven mesh refinement and implementation of various turbulence models.
Regarding the document, you will need to worry about confidentiality because the report was never released to the public.
Hrv
Hrvoje Jasak
Old   January 10, 2012, 08:53
Default Reference request for LienCubicKELoeRe model.
  #15
Saeed Salehi
salehi144 is on a distinguished road
Hi.
I'm using the LienCubicKELoeRe model in OpenFOAM.
Unfortunatley i couldn't find a reference for this model. the main paper (" Low-Reynolds-number eddy-viscosity modeling based on non-linear stress-strain/vorticity relations ") is not available online (or i couldnt find it).
does anyone have this paper on one similar that has the LienCubicKELoeRe model formulation.
Thanks.
salehi144 is offline   Reply With Quote
