August 26, 2010, 04:13 |
label/scalar mixup in hierarchGeomDecomp.C
Michael Wild
Rep Power: 17 |
The bug is in src/decompositionMethods/decompositionMethods/hierarchGeomDecomp/hierarchGeomDecomp.C:
279 label weightedSize = returnReduce 280 ( 281 sortedWeightedSizes[mid] - sortedWeightedSizes[minIndex], 282 sumOp<label>() 283 ); Code:
--- a/src/decompositionMethods/decompositionMethods/hierarchGeomDecomp/hierarchGeomDecomp.C +++ b/src/decompositionMethods/decompositionMethods/hierarchGeomDecomp/hierarchGeomDecomp.C @@ -276,10 +276,10 @@ void Foam::hierarchGeomDecomp::findBinary while (true) { - label weightedSize = returnReduce + scalar weightedSize = returnReduce ( sortedWeightedSizes[mid] - sortedWeightedSizes[minIndex], - sumOp<label>() + sumOp<scalar>() ); if (debug) |
August 26, 2010, 05:31 |
Michael Wild
Rep Power: 17 |
Similarly for src/dynamicMesh/slidingInterface/slidingInterface.C:
--- a/src/dynamicMesh/slidingInterface/slidingInterface.C +++ b/src/dynamicMesh/slidingInterface/slidingInterface.C @@ -706,12 +706,12 @@ void Foam::slidingInterface::setTolerances(const dictionary&dict, bool report) "edgeMergeTol", edgeMergeTol_ ); - nFacesPerSlaveEdge_ = dict.lookupOrDefault<scalar> + nFacesPerSlaveEdge_ = dict.lookupOrDefault<label> ( "nFacesPerSlaveEdge", nFacesPerSlaveEdge_ ); - edgeFaceEscapeLimit_ = dict.lookupOrDefault<scalar> + edgeFaceEscapeLimit_ = dict.lookupOrDefault<label> ( "edgeFaceEscapeLimit", edgeFaceEscapeLimit_ |
August 27, 2010, 06:28 |
Mattijs Janssens
Rep Power: 26 |
Thanks, I've pushed them into 1.7.x. By the way, how did you find these - gcc4.4 does not seem to warn about them.
We've finally got a proper bug reporting system :-) Please report any future bugs on http://www.openfoam.com/bugs. |
August 27, 2010, 08:53 |
Michael Wild
Rep Power: 17 |
gcc4.1.2 does ;-) probably 4.4 would too with proper warning flags.
Kudos for the Mantis bug tracker! At last, I'd say :-) |
February 16, 2012, 11:33 |
Naveed Iqbal
Rep Power: 16 |
Hi Michael,
It would be very nice if you might explain a little bit about this function call returnReduce(. ,. ). I have find its definition "PstreamReduceOps.H" but could not understand what this will return. Your short description about this function would help me a lot. Thanks in Advance |
February 16, 2012, 14:18 |
Michael Wild
Rep Power: 17 |
returnReduce() is a reduction operation (e.g. sum, min, max, cumulative sum, product, cumulative product, etc) across all processors for parallel runs. The first argument is the value on the local processor and the second argument is the binary operator performing the reduction operation between two arguments. This can be a functor or a function pointer.
The problem in the reported issue is that the functor objects where created for label type (i.e. int), while the value argument was a scalar (i.e. double or float). HTH Michael |
February 17, 2012, 03:43 |
Naveed Iqbal
Rep Power: 16 |
Hi Michael,
Thanks for the prompt reply. It clarifies the things I am looking at. |
