pointD BCs for FSI with fixedDisplacementZeroShear BCs
I am trying to validate solids4Foam FSI for arterial flows. My validation case is a Moens-Korteweg situation with a pressure jump at t=0, using a short 3d tube geometry as in: Lee, S. H., Choi, H. G. and Yool, J. Y. (2012) ‘Finite element simulation of blood flow in a flexible carotid artery bifurcation’, Journal of Mechanical Science and Technology, vol. 26, no. 5, pp. 1355–1361 [Online]. DOI: 10.1007/s12206-012-0331-9. The case is quite similar to the 3dTube tutorial, but with a full 3d tube instead of the 2 symmetry conditions. I started with the rigidly fixed BCs at inlet and outlet: Code:
D: Code:
pointD: Code:
D: Code:
pointD/pointDD: Code:
calculated Which BC for pointD is compatible with fixedDisplacementZeroShear? Or which combination of BCs can I use to allow for movement in the plane? Another one: Is there a BC that will provide a non-reflective BC on the outlet side for the fluid? But I will put that in a separate thread. Thanks T |
