[FSI] Unable to run HronTurekFSi tutorials in parallel |
November 29, 2019, 02:09 |
#1 | |
Matte Wang
Rep Power: 7 |
Hello, everyone. I am a beginners to FSI problems and now I have a problem about the icoFsiElasticNonLinULSolidFoam.
Every thing is Ok when I start the simulation by ./Allrun However, the simulations abort quickly when I use the script AllrunPar. The log files is : Quote:
November 29, 2019, 05:27 |
Matte Wang
Rep Power: 7 |
All right. Things go well when I switch to foam-extend4.0.
It seems that this is a bug in beta version. |
November 29, 2019, 07:30 |
#3 | |
Matte Wang
Rep Power: 7 |
Hi every one. I have come back.
Now I want to install the Fluid-structure_interaction toolkit. I follow the guides of https://openfoamwiki.net/index.php/E...re_interaction. However, I my compiler encounter many errors like this : Quote:
fluidSolid.txt Now my OF version is foam-extend 4.0. My ubuntu system is 18.04.3 Anyway, if someone know the reason of this problems, please give me a hand. Thank you . |
December 18, 2019, 14:15 |
Hojatollah Gholami
Rep Power: 7 |
May it be late, but for other person.
As it seen, the problem was from compiler. Maybe changing from extend4.1 to 4.0 lead to defining gcc7. As the Daniel mentioned, you should follow instructions as solids4Foam twoElasticBeams tutorial: multiple FSI interfaces So you need to clean first and run from first https://openfoamwiki.net/index.php/I...oam-extend-4.0 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
[snappyHexMesh] Able to run snappyHexMesh in parallel on local machine but unable to run on linux clu | abhinav2601 | OpenFOAM Meshing & Mesh Conversion | 1 | January 26, 2015 05:42 |
unable to run in parallel with OpenFOAM 2.2 on CentOS | einatlev | OpenFOAM Running, Solving & CFD | 9 | June 26, 2014 00:24 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
Unable to run OF in parallel on a multiple-node cluster | quartzian | OpenFOAM | 3 | November 24, 2009 13:37 |
