[FSI] [foam-extend-4.1/extend-bazaar] Issue building the "beamInCrossFlow" tutorial case |
December 18, 2019, 15:09 |
#1 | |
Hi everyone,
I compiled extend-bazaar, respectively the version which is included in the foam-extend-4.1 package. Afterwards, I tried to build and run some of the FSI examples included in extend-bazaar. Unfortunately, I was not able to build the "beamInCrossFlow" example (path: /extend-bazaar/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/). I followed the instructions from the OpenFOAM-Wiki for the FSI tutorial cases (https://openfoamwiki.net/index.php/E...tutorial_cases), but when I was running the "Allrun" script, I got the following error by g++: Code:
/foam/foam-extend-4.1/src/foam/lnInclude/runTimeSelectionTables.H:73:40: error: invalid new-expression of abstract class type ‘Foam::setInletVelocity’ return autoPtr< baseType >(new baseType##Type parList); \ Issue compiling solver for OF 2.4 According to that thread, the error occurs when there are virtual functions which have not been implemented yet. With regard to this specific case, there are three virtual functions in "setInletVelocity.H" (path: .../beamInCrossFlow/setInletVelocity/): Quote:
Has anybody encountered this problem before? Why does this error occur? What are the missing functions to implement? Thanks for your help! |
September 2, 2020, 12:59 |
Ra Miro
Rep Power: 5 |
I have the same problem.
Has anyone fixed it? |
December 3, 2021, 12:14 |
Rep Power: 6 |
I have the same problem, have you solved it? |
extend-bazaar, foam-extend-4.1, fsi |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
SRFSimpleFoam tutorial case blows up on laptop (but runs on desktop?) | AHMeng | OpenFOAM Running, Solving & CFD | 1 | April 27, 2012 08:34 |
FoamX refuses to open an interFoam tutorial case | vrecha | OpenFOAM Pre-Processing | 5 | March 12, 2008 12:36 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
