Hgholami |
January 19, 2020 22:04 |
here is log of simulation
Create time
| For further information on the solids4Foam toolbox implementations, |
| please see the following publications: |
| P. Cardiff, A Karac, P. De Jaeger, H. Jasak, J. Nagy, A. Ivankovic, |
| Z. Tukovic: An open-source finite volume toolbox for solid mechanics and |
| fluid-solid interaction simulations. arXiv:1808.10736v2, 2018, available |
| at https://arxiv.org/abs/1808.10736. |
| Z. Tukovic, A. Karac, P. Cardiff, H. Jasak, A. Ivankovic: OpenFOAM |
| finite volume solver for fluid-solid interaction. Transactions of |
| Famena, 42 (3), pp. 1-31, 2018, 10.21278/TOF.42301. |
Selecting physicsModel fluidSolidInteraction
Selecting fluidSolidInterface method fixedRelaxation
Selecting fluidModel buoyantBoussinesqPimpleFluid
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityLaplacian
Selecting motion diffusion: quadratic
Selecting motion diffusion: inverseDistance
Reading g from constant directory
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
PIMPLE: Operating solver in PISO mode
Selecting solidModel unsThermalNonLinearGeometryTotalLagrangian
Selecting dynamicFvMesh staticFvMesh
Creating fixedDisplacement boundary condition
Creating solidTraction boundary condition
limiter coefficient: 1
under-relaxation method: fixed
Selecting thermal model constant
Selecting thermal source model constant
Creating the mechanicalModel
Number of cells in new mesh : 210
Number of faces in new mesh : 877
Number of points in new mesh: 496
Number of cells in new mesh : 15480
Number of faces in new mesh : 62273
Number of points in new mesh: 31662
Selecting mechanical law neoHookeanElastic
Creating pointDisp function object
pointDisp: distance from specified point is 0.501983
--> FOAM Warning :
From function polyBoundaryMesh::patchSet(const wordList&)
in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 444
Cannot find any patch names matching plate
Time = 2e-05
Create GGI zone-to-zone interpolator for interface patch: elastic
Checking fluid-to-solid face interpolator
Fluid-to-solid face interpolation error: 8.93054e-05
Checking solid-to-fluid point interpolator
calcMasterPointAddressing() const
Extended GGI, master point distance, max: 2.91029e-09, avg: -1.88843e-11, min: -2.83433e-09
Solid-to-fluid point interpolation error: 2.91029e-09
Number of uncovered master faces: 0
Number of uncovered slave faces: 0
calcSlavePointAddressing() const
Extended GGI, slave point distance, max: 2.91029e-09, avg: -2.13943e-11, min: -2.67616e-09
Extended GGI, slave point orientation (<0), max: -0.57735, min: -1, nIncorrectPoints: 0/3968
Create GGI zone-to-zone interpolator for interface patch: finsurface
Fluid-to-solid face interpolation error: 0.000757033
Extended GGI, master point distance, max: 4.3e-10, avg: -7.91339e-11, min: -8.6e-10
Solid-to-fluid point interpolation error: 8.6e-10
Extended GGI, slave point distance, max: 4.32124e-10, avg: -1.17861e-10, min: -2.90699e-09
Extended GGI, slave point orientation (<0), max: -0.5547, min: -1, nIncorrectPoints: 0/15881
Setting traction on solid patch/patches
Interpolating from fluid to solid using GGI/AMI interpolation
Total force on interface patch elastic (fluid) = (-0.00025061 -1.37098e-07 1.29725e-08)
Total force on interface patch finsurface (fluid) = (-0.00012649 2.9411e-10 -8.03204e-09)
Total force on interface patch elastic (solid) = (0.00025061 1.37098e-07 -1.29723e-08)
Total force on interface patch finsurface (solid) = (0.000126489 -2.9411e-10 8.03234e-09)
Evolving thermal solid solver
Solving coupled energy and displacements equation for T and D
setCellDisplacements: reading cellDisplacements
Corr, res (T & D), relRes (T & D), matRes, iters (T & D), enforceLinear
The residuals have converged
4, 1.08963e-07, 0, 9.69549e-07, 0, 0, 1, 0, false
Solid temperature min/max(T) = 300, 350 [K]
Interpolating from solid to fluid using GGI/AMI interpolation
Current fsi relative residual norm (elastic): 0
Alternative fsi residual (elastic): 0
Current fsi relative residual norm (finsurface): 0
Alternative fsi residual (finsurface): 0
Time = 2e-05, iteration: 1
Current fsi under-relaxation factor: 0.7
Creating accumulated fluid interface displacement for global patch elastic from disk...
Creating accumulated fluid interface displacement for global patch finsurface from disk...
Maximal accumulated displacement of interface points: 0
GAMG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 1
GAMG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 1
GAMG: Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 1
Evolving fluid model: buoyantBoussinesqPimpleFluid
Minimum cell dimension: 7.07106e-05
Fourier number mean: 0.00635554 max calculated: 0.0862859
Courant Number mean: 0.00477723 max: 0.0982439 velocity magnitude: 1.37912
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 5.40798e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 4.88039e-07, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 4.33661e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 1, Final residual = 9.71662e-07, No Iterations 141
GAMG: Solving for p, Initial residual = 1.12044e-07, Final residual = 1.18199e-07, No Iterations 1
time step continuity errors : sum local = 7.55598e-11, global = 3.28983e-11, cumulative = 3.28983e-11
GAMG: Solving for p, Initial residual = 0.0244118, Final residual = 9.45265e-07, No Iterations 63
GAMG: Solving for p, Initial residual = 9.67213e-07, Final residual = 9.26203e-07, No Iterations 1
time step continuity errors : sum local = 5.80932e-10, global = -2.41695e-10, cumulative = -2.08797e-10
GAMG: Solving for p, Initial residual = 0.000679864, Final residual = 8.80981e-07, No Iterations 13
GAMG: Solving for p, Initial residual = 8.81202e-07, Final residual = 7.89326e-07, No Iterations 1
time step continuity errors : sum local = 4.94946e-10, global = -1.83483e-10, cumulative = -3.9228e-10
DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 6.60637e-07, No Iterations 2
Fluid temperature min/max(T) = 299.951, 350 [K]
Total force on interface patch elastic (fluid) = (-0.145881 7.18523e-05 -0.0627234)
Total force on interface patch finsurface (fluid) = (-0.109132 3.44053e-08 7.53123)
Total force on interface patch elastic (solid) = (0.145881 -7.18524e-05 0.0627234)
Total force on interface patch finsurface (solid) = (0.109132 -3.43916e-08 -7.53122)
2, 2.3012e-11, 0, 0, 0, 0, 0, 0, false
ExecutionTime = 45.67 s ClockTime = 46 s
--> FOAM FATAL ERROR:
request for newLeastSquaresVolPointInterpolation newLeastSquaresVolPointInterpolation from objectRegistry solid failed
available objects of type newLeastSquaresVolPointInterpolation are
0
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/itp/foam/foam-extend-4.0/src/foam/lnInclude/objectRegistryTemplates.C at line 139.
FOAM aborting
Aborted (core dumped)
