March 31, 2017, 03:19 |
FsiFoam 4.0 - can not run tutorials
Ervin Adorean
Rep Power: 17 |
I have compiled Foam-extend 4.0 and the corresponding FsiFoam package on Slackware 14.2. Foam-extend runs fine. When trying to run the included FsiFoam tutorials I get the error: "flux requested but p not specified in the fluxRequired sub-dictionary of fvSchemes", but that is not the case, the mentioned entry being in place. What could be the real issue here? Thank you! Ervin |
April 19, 2017, 16:13 |
Thomas
Hello Ervin,
i had the same problem. If you check out the bugfix https://sourceforge.net/p/foam-exten...502bb3bc0040e/ you can find that they disabled the reading of "fluxRequired" by commenting this part in src/finiteVolume/finiteVolume/fvSchemes/fvSchemes.C. I simply uncommented lines 382-392. It works fine for me since i only use fsiFoam. Do not forget wmake libso. Best regards Thomas |
July 4, 2017, 05:08 |
#3 | |
WA
Rep Power: 8 |
what do you mean "do not forget to wmake libso"? I executed "./Allclean and ./Allwmake" for the foam-extend-4.0 in the dictionary of $HOME/foam-extend-4.0, but it does not work. It still occurred the same error. |
August 10, 2017, 04:44 |
Rep Power: 12 |
I am also having the "p not specified in the fluxRequired sub-dictionary of fvSchemes" error on foam-extend 4.0. This is a case which runs smoothly on foam-extend 3.2. There should be a reason why the flux required option is disabled. Thanks in advance, Utku |
August 16, 2017, 05:45 |
Problem, too
#5 | |
Rep Power: 12 |
Hi!
I experience the same error and the above bugfix by Hvorje doesn't work for me. Quote:
August 16, 2017, 10:11 |
Found the error
Rep Power: 12 |
Hi Guys, I solved the issue here,
there is one line in at the very end in createFields.H, that's new in fext 4.0: Code:
mesh.schemesDict().setFluxRequired(p.name()); Regards, Ma-tri-x |
August 18, 2017, 11:36 |
#7 | |
Rep Power: 8 |
Can you please clearly explain where to integrate the line? because it is already there in the file "createFields.H". Thanks & Regards Big_bird |
August 21, 2017, 05:31 |
where to integrate
Rep Power: 12 |
HI Big_bird,
I did 3 things in total: - apply patch to fvSchemes.C (the above buxfix) - in src/finiteVolume/fvMatrices/fvMatrix/fvMatrix.C comment the following lines: Code:
if (!psi_.mesh().schemesDict().fluxRequired(psi_.name())) { FatalErrorIn("fvMatrix<Type>::flux()") << "flux requested but " << psi_.name() << " not specified in the fluxRequired sub-dictionary" " of fvSchemes." << abort(FatalError); } Code:
cd $WM_PROJECT_DIR cd src wmake libso to your createFields.H mesh.schemesDict().setFluxRequired(p.name()); |
August 21, 2017, 15:04 |
#9 | |
Rep Power: 8 |
Hi matrix,
Thanks for your reply. I just only did the 3rd point you mentioned i.e, adding the line Quote:
September 24, 2017, 16:08 |
#10 |
Luofeng
Rep Power: 9 |
Hi big_bird
Can you please tell me which file did you revised? i.e. where the createFields.H located? there are so many in the foam. Cheers Luofeng |
September 28, 2017, 05:05 |
#11 |
anonymous
Rep Power: 9 |
I am also having trouble with this. Where is createFields.H found? I can't find any reference to it in the fsitoolkit source code. Regards, RH.
October 4, 2017, 12:28 |
#12 |
Rep Power: 12 |
$WM_PROJECT_DIR/applications/solvers/some_sub_dir/the_solver_you_are_using/createFields.H
October 5, 2017, 04:21 |
#13 | |
anonymous
Rep Power: 9 |
/incompressible/icoFoam/createFields.H: Code:
label pRefCell = 0; scalar pRefValue = 0.0; setRefCell(p, piso.dict(), pRefCell, pRefValue); mesh.schemesDict().setFluxRequired(p.name()); Code:
Evolving fluid solver: consistentIcoFluid Courant Number mean: 2.74517e-18 max: 0.425797 velocity magnitude: 0.0464238 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.27614e-07, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.988361, Final residual = 8.95334e-07, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.985989, Final residual = 9.63029e-07, No Iterations 4 GAMG: Solving for p, Initial residual = 1, Final residual = 7.79802e-07, No Iterations 19 GAMG: Solving for p, Initial residual = 2.59508e-05, Final residual = 3.63815e-07, No Iterations 2 --> FOAM FATAL ERROR: flux requested but p not specified in the fluxRequired sub-dictionary of fvSchemes. calcPhi.H consistentIcoFluid.C consistentIcoFluid.dep consistentIcoFluid.H Many thanks, RH. |
October 19, 2017, 04:08 |
#14 |
anonymous
Rep Power: 9 |
October 19, 2017, 13:43 |
#15 |
Hassan Adel
Rep Power: 12 |
Hallo
I face the same problem Can anyone tell us what shall we do indetails?
H.Elsheshtawy |
October 19, 2017, 15:25 |
Solved
#16 | |
Rep Power: 8 |
Hi everyone,
Apologies for the late reply. The "createFields.H" will be located inside the folder of the solver which you are using. just paste this line of code Quote:
Best Regards Big_bird |
October 23, 2017, 06:43 |
#17 | |
anonymous
Rep Power: 9 |
Hi Big_bird, I'm not sure about this fix. Please see my post above (#13): HTML Code:
https://www.cfd-online.com/Forums/openfoam-solving/185685-fsifoam-4-0-can-not-run-tutorials.html#post666611 |
November 22, 2017, 04:34 |
#18 | |
anonymous
Rep Power: 9 |
All/hassan1201, I had help from a member called alia in a separate thread. I inserted one line of code into the evolve() function for each fluidSolver (i.e. consistentIcoFluid.C, icoFluid.C, pisoFluid.C) Insert Code:
mesh.schemesDict().setFluxRequired(p().name()); Code:
const fvMesh& mesh = fluidSolver::mesh(); src/fluidSolidInteraction/fluidSolvers/consistentIcoFluid/consistentIcoFluid.C src/fluidSolidInteraction/fluidSolvers/icoFluid/icoFluid.C src/fluidSolidInteraction/fluidSolvers/pisoFluid/pisoFluid.C Then I ran ./Allwmake to update and the tutorial ran fine. RH. |
November 25, 2017, 17:05 |
#19 |
Sam
Rep Power: 8 |
@rr3245 thanks men, you're a lifesaver.
June 2, 2018, 12:53 |
#20 | |
Sangeet
Rep Power: 8 |
Thank you GOD. fsiFoam tutorials finally running on foam-extend 4.0 . |
[waves2Foam] Compiled with foam-extend-4.0, but I cannot run tutorials in parallel | lxwd | OpenFOAM Community Contributions | 7 | February 22, 2017 02:13 |
OpenFOAM can't be run in parallel in cluster | sibo | OpenFOAM Running, Solving & CFD | 4 | February 21, 2017 16:29 |
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 17:19 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
