Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] How to add temperature to icoFluid
Old   October 16, 2021, 10:55
Default How to add temperature to icoFluid
roozbeh
roozbeh_s is on a distinguished road
Dear Philip,
I want to do a similar procedure as in https://openfoamwiki.net/index.php/H...ure_to_icoFoam
in icoFluid of solids4foam. I did the following:
            IOobject::MUST_READ,
            IOobject::NO_WRITE
    nu_(transportProperties_.lookup("nu")),
    rho_(transportProperties_.lookup("rho")),
//***********Temp parameters
    DT_(transportProperties_.lookup("DT"))
Then I want to define volScalarField T but I don't know where should I define it, I mean this part:
volScalarField T
    IOobject
         "T",
         runTime.timeName(),
         mesh,
         IOobject::AUTO_WRITE
     mesh
Could you help me pleas?
roozbeh_s is offline   Reply With Quote
Old   October 21, 2021, 11:53
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Originally Posted by roozbeh_s View Post
Dear Philip,
            IOobject::NO_WRITE
volScalarField T
    IOobject
         "T",
         runTime.timeName(),
         mesh,
     mesh
The "volScalarField T" should be added as a private member to the icoFluid class (to the H file) and then added to the constructor in the C file.
Philip
bigphil is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
How to add temperature on DPM particles? Maple_cfd OpenFOAM Running, Solving & CFD 0 April 10, 2018 03:43
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 09:23
