Foam-Extend 4.1 Extend Bazaar Allwmake fail compiling on Opensuse Tumblweed
1 Attachment(s)
Hello OpenFOAM CC,
I hope everyone is doing well. So a little background. I am running Opensuse Tumbleweed on a 6 core VM based on an i7 7700HQ. I was able to compile Foam Extend 4.1 using the instructions for building 4.0. It had no errors and runs fine. I wanted to try the FSI and solid tutorials from the bazaar so I attempted to build it using the files given in the extended bazaar folder of the foam-extend4.1 package. It fails after awhile with 2 errors (one for FSI and one for AxialMesh) I then edited the allwmake file to build each one individually with logs. So here they are: FSI: Code:
cc1plus: all warnings being treated as errors Code:
makeAxialMesh.C:52:10: fatal error: Time.H: No such file or directory So does anyone know what the issue could be? I am just trying to get everything setup so I can learn about fsi. |
