solver settings for unsLinearGeometry
I am using solids4Foam to obtain displacements for a complex geometry. The mesh has a combination of hexahedra and polyhedra cells and the total cell count is 1.8 mil. Even after 4 hours, the 24 core parallel solver runs only 1100 iterations at the first time step and not converged. A few settings of the case are: "linearGeometryTotalDisplacementCoeffs|unsLinearGe ometryCoeffs" { nCorrectors 10000; solutionTolerance 1e-06; alternativeTolerance 1e-07; materialTolerance 1e-05; infoFrequency 100; } solvers { D { solver PCG; preconditioner FDIC; tolerance 1e-09; relTol 0.01; } } 'Harmonic' interpolation is set for impK. May I know if any of the above settings are not suitable for complex geometry or is it that the solver cannot handle combination of hexahedra and polyhedra cells? Appreciate any help or views on this. Thanks |
Hi Barry,
Can you give more details on your case? For example, a simple sketch of the problem showing the boundary conditions and materials properties. Lack of convergence can be due to one of several issues, including:
Philip |
1 Attachment(s)
Thanks for your reply Phil.
In the attached, left fig shows geometry used for simulations and the right fig is zoom in version of a joint. Three colors in the left fig indicate mesh resolutions that differ by a level with coarser being at the bottom. The boundary conditions are time varying traction for the top two parts and fixed displacement for the bottom part and indicated in the left fig. The solidModel is 'unsLinearGeometry' and the specifications are mentioned in the above query. The solidProperties specified are mechanical ( steel { type linearElastic; rho rho [1 -3 0 0 0 0 0] 700; E E [1 -1 -2 0 0 0 0] 2e+9; nu nu [0 0 0 0 0 0 0] 0.3; } ); From this info, is it possible to infer reasons for non-convergence? B |
In addition to the above, may I know what's the difference between linearGeometryTotalDisplacement and linearGeometry?
Both should give the same answer but there may be a difference in the convergence and speed. |
I'm also having same problem, just wondering why for high density, stiffness material it runs very slow. I've tried changing the material in the HronTurek tutorials from rubber to steel, and set for linearElastic model but takes too long for my laptop. Any tips to run FSI for steel-water? Tq |
Philip |
I've tried changing the material model to St Venant Kirchhoff, it keeps on giving the same as NeoHookean Quote:
By the way, how could I tail -f the displacement if run in parallel? it keep on showing 0 displacement. Thank you |
Philip |
Thanks for the reply, I'd solve the error in the point displacement function by reinstalling the solids4Foam. I'm facing two problem in trying to simulation vibration of steel in water. 1.Do you have any tips on reducing the numerical damping? I've used the backward temporal discretization and tried reducing the displacement solution tolerance in the solidProperties. 2. There seem to be small fluctuations in the displacement, and when I to set a case with vibration inside a water would cause larger fluctuation in flow velocity and diverge the simulation. How to remove this fluctuation? Thank you |
2. This may be related to the backward scheme (see point 1). If not, then I cannot say what the sources of the fluctuations without knowing more about the case. When using water the fluid/solid density becomes larger which makes it more difficult for the FSI coupling procedure; smaller initial FSI relaxation factors may help. Philip |
I'm working on a tube with poisson 0.45, young's modulus equal to 1.5 * 10 ^ 6. I impose a velocity at the inlet that varies over time and a pressure at the outlet that depends on the flow at the outlet. I noticed that the two solid models (linearGeometry and unsLinearGeometry) don't give me the same deformation. In the linearGeometry case I get what I want, with unsLinearGeometry instead I have an expansion of the tube that remains fixed over time. It's possible? |
An if so, which version of OpenFOAM are you using? All the linear geometry solid models should approach the same answer as the mesh is refined. |
Thanks for the quick reply.
My fluid boundary conditions are: velocity - pulsatile inlet velocity with backflow - Outlet: advective - on the wall: newMovingWallVelocity Pressure -Inlet: zeroGradient; -Otlet: pressure variable over time according to the flow rate -wall:extrapolatedPressure. The boundary conditions on the solid are the same as in the tutorial. I had to change IQNILS to Aitken, because the simulation exploded. This simulation aims to reproduce the blood flow in the artery. |
I have run other simulations with more refined meshes, I have reduced the tolerance on the equation of the moment of the equation on the solid and I now get the explosion of the simulation. The forces exchanging at the interface are too high. I augmented the young module and so the simulation works, but I don't get the correct displacements. So I need to work with my young module. I tried using IQNILS, delaying coupling, but it doesn't work. I have tried to use a hyperelastic solid model, but I always get the explosion of the simulation. I also did separate solid and fluid simulations and they work. Do you have any suggestions for me? Thanks for your time. |
I go back to asking for help with my simulations. I changed mesh, now I have a tube bent at 90° to simulate blood flow in an artery. I notice the following behavior during the simulation: to reach the convergence on the fsi loop with a tolerance of 10 ^ - 2, it takes more than 100000 cycles and, during these cycles, the Courant number increases, until the explosion. I cannot understand the reason for this behavior. Is there any way to speed up the simulation? I used the fixedRelaxation coupling method with value 10 ^ -5, other methods and higher values don't work. The same simulation but with straight pipe works without problems. Thank you for your time, I really need to unlock this if you can give me any suggestions. |
how can i map the weights of AMI? |
