February 18, 2022, 13:32 |
solidProperties mystery
Merlin Williams
Rep Power: 4 |
I am trying to run an FSI simulation and in my process to getting there I am trying to understand the solid mechanics part of it. However despite a lot of searching I have barely found any information on the solidProperties dictionary. Please can somebody please explain the solid properties dicitonary and its entries as well as the different solid models available? Also does the solid model chosen have any bearing on if you need to include pointD and pointDD in the 0 folder? Thank you in advance Merlin |
February 19, 2022, 03:40 |
#2 | |
Hojatollah Gholami
Rep Power: 7 |
Your question is general. First you should look at the code, that where the solidProperties dictionary calles. then explain your question. Quote:
February 19, 2022, 09:57 |
Merlin Williams
Rep Power: 4 |
Sorry for the general nature of the question it is because of my limited knowledge of the solidProperties dictionary and hence I am not exactly sure of the extent of what I do not know, if that makes sense.
1. I understand the solidModel prefix 'uns-' stands for unstructured but does this refer to the mesh being unstructured and so are these solidModels reccomended when using an unstructured mesh? 2. What is the difference between a 'totalLagrangian' model and an 'updatedLagrangian' model? 3. What is the difference between having the increment displacement or the total displacement as the primary unknown? Is the difference only noticed when post processing and analysing the results or must some simulations choose a specific one? 4. Do you determine which of D, DD, pointD and pointDD are required in 0 by reading the .C file in src/solids4FoamModels/solidModels? 5. What are the benefits of a block coupled solution over a segregated solution? I hope that is slightly less general, and I would appreciate anyones time if they can answer them. Best regards Merlin |
February 26, 2022, 07:37 |
#4 | |||||
Hojatollah Gholami
Rep Power: 7 |
Hi
for abstract: in updated Lagrangian, all variables being referred coressponding to the last calculated configuration. In total Lagrangian, all variables being referred coressponding to the initial configuration at time t=0. Quote:
Trick: rename all D,DD,pointD,pointDD and run the each solid model. the solver give error and write each require file. Quote:
https://foam-extend.fsb.hr/wp-conten..._20Sep2018.pdf In my expriment, the segregated method is faster than coupled in fluid solver. in solid solver, I don't experiment with coupled. |
mechanics, solid body |
Display Modes | |
Using a variable as rho in solidProperties in FSI case | BiomechanicsBath | OpenFOAM Pre-Processing | 0 | November 21, 2017 05:11 |
Mystery of the two models | Shamoon Jamshed | FLUENT | 9 | July 20, 2016 13:54 |
solidProperties in reactingParcelFoam | kalei | OpenFOAM Running, Solving & CFD | 0 | December 16, 2015 09:25 |
3 discretisation solving questions | kar | OpenFOAM Running, Solving & CFD | 10 | October 14, 2008 07:11 |
