Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] codeStream for pressure boundary condition in 0/solid/D
Old   October 20, 2025, 22:59
Default codeStream for pressure boundary condition in 0/solid/D
Sam Mallinson
SamMallinson is on a distinguished road
I wish to express a pressure load on a solid wall as a function of location.
I have been using the traction BC in 0/solid/D to apply a fixed value pressure, but the case I am computing requires the pressure to be a function of distance from a point.
Is it possible to use codeStream to do this?
I think this might be tricky as the traction BC is for displacements, and I want to apply a pressure.
Details of system:
OpenFOAM: Build : _76d719d1e6-20220624 OPENFOAM=2206 version=v2206
solids4foam: installed March 2025 via repository
OS: Ubuntu 20.04
SamMallinson is offline   Reply With Quote
Old   October 21, 2025, 19:03
Default implementation
Sam Mallinson
This is what I tried:
in `0/solid/D`, at the top of the file, I had
#include "pressureCondition"
then in the body
compression-force
type solidTraction;
traction uniform ( 0 0 0 );
value uniform (0 0 0);
pressure $pressureF;
The file `pressureCondition` is as follows:
pressureF #codeStream
code
scalar D = 0.003;
scalar A = 2 * 3.14159 * 0.002 * D;
const IOdictionary& d = static_cast<const IOdictionary&>
dict.parent().parent()
const fvMesh& mesh = refCast<const fvMesh>(d.db());
const label id = mesh.boundary().findPatchID("compression-force");
const fvPatch& patch = mesh.boundary()[id];
scalarField myPatch(patch.size(), scalar(0) );
forAll(myPatch, celli)
scalar zc = patch.Cf()[celli][2];
myPatch[celli] = scalar(250 * pow(Foam::constant::mathematical::e, ((-4 * pow(zc,2))/(pow((4 * D),2))) ) / A);
operator == (myPatch);
codeInclude
#include "fvCFD.H"
#include "volFields.H"
codeOptions
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(FOAM_CASE)/system
codeLibs
-lfiniteVolume \
-lmeshTools
#inputMode merge
codestream, solids4foam
How to update Boundary Condition in the loop with #codeStream? TeddyL OpenFOAM 0 October 20, 2024 03:56
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Radiation interface hinca CFX 15 January 26, 2014 18:11
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
