Why no non-zero return codes?
I'm wondering why some (all?) pyFoam tools do not return a non-zero return code if the openfoam tool fails. For example: pyFoamRunner.py --autosense-parallel potentialFoam -noFunctionObjects fails because there is some dictionary entry missing, the return code is 0. mpirun -n 2 potentialFoam -noFunctionObjects fails too, but with a return code of 1. Same for pyFoamRunner.py. Returning non-zero exit code to indicate an error makes it much easier for scripts to use pyFoam. Any reason for this design decision or just not implemented yet? Regards, Florian |
- I didn't need it yet (I don't check return codes in shell-scripts. If that is necessary I use Python) - there was no feature-request on the Mantis yet So this is NO design decision |
Ok, the bugtracker is offline at the moment, I will file a request later and will also have a look at the code and see if I can produce a patch.
